FME Transformers: 2025.0
TextLocationExtractor
Replaces text with its location geometry, usually a point.
- Converting text labels to points
- Working with complex annotation input
- Restoring non-point geometry stored with text
The TextLocationExtractor receives features with text geometry and converts them to whatever non-text geometry exists on the feature.
This will usually be a point, but may also be a line or curve representing annotation, or geometry of any type that has been stored using the TextAdder.
Text properties including the text string, size, and rotation are discarded. To extract them into attribute values, use a TextPropertyExtractor prior to the TextLocationExtractor.
In this example, we have a set of text labels and want to convert them to simple point geometry.
The features are routed into a TextLocationExtractor. There are no parameters to set.
The output features are points, and the text properties have been discarded.
In this example, we have a set of complex annotations that have been retrieved from a geodatabase.
In their source environment, these cartographic labels follow the course of waterways. FME Data Inspector (and most formats) cannot render that detail, so the labels are displayed as normal text.
Note that in addition to the Text Location as Point coordinates, the selected feature also has aggregate multipoint geometry stored.
The text is replaced with geometry representing the original annotation, which can be further manipulated.
If the label text strings are not already stored as an attribute, they can be retrieved by using a TextPropertyExtractor prior to the TextLocationExtractor.
- To extract a text feature’s coordinates into attributes, use a CoordinateExtractor.
- To convert text to a vector representation, use a TextStroker.
- For an example of storing and restoring non-point geometry to/from text features, see the TextAdder.
- For an example of working with complex annotation, see Working with Curved Multi-part Geodatabase Annotation.
Creating and Modifying Point and Text Features
These transformers work with points, text, and labels in a variety of ways.
Transformer |
Use this to... |
Transformer Description |
Create one or more new features with box geometry of a specific size and position (when Geometry Object is Point or Text). |
Replace a feature’s geometry with a point at a specified location. |
Creates a single vertex to replace, be appended to, or be inserted into existing geometry. |
Create points inside features or their bounding boxes. |
Replaces feature geometry with a point located within the feature, its bounding box, or at its center of mass. |
Extract the coordinates of a calculated point within the feature. |
Extracts the coordinates of a point located within the feature, its bounding box, or at its center of mass, and stores them as attributes. |
Create new regularly-spaced points in a specified location. |
Create new regularly-spaced points over the extents of other features. |
Create points from every vertex of input line or area geometry. |
Chops line, arc, path, or area features into smaller features based on number of vertices or approximate length. |
Create points where features intersect. |
Computes intersections between all input features, breaking lines and polygons wherever an intersection occurs and creating nodes at those locations. |
Create points from point cloud features. |
Label lines. |
Places labels along a linear feature, angled to the orientation of each labeled segment. |
Label points at an angle. |
Replaces any geometry with a single text label at the center of its bounding box. |
Label points and areas. |
Replaces point, line, or area geometry with a single text label. |
Convert text to geometry. |
Replaces text with its location geometry, usually a point. |
Extract text properties into attributes. |
Retrieves text property values from text geometry, adding them to the feature as attributes. |
Set or modify text properties. |
Modifies or creates text geometry according to new coordinates, text string, size, or rotation values. |
Convert text to non-text geometry. |
Converts text to aggregate line or area geometry according to a specific True Type font. |
Extract point properties into attributes. |
Extracts point orientation to feature attributes. |
Set or modify point properties. |
Adds or removes point orientation. |
Geometry |
Recommended Transformer |
Example |
Point |
Line |
Area
Feature with text geometry.
Features with text replaced by point or other location geometry.
Features with geometry other than text are output here.
Rejected features will have an fme_rejection_code attribute with the following value:
Search for all results about the TextLocationExtractor on the FME Community.
