RasterGCPExtractor
Extracts Ground Control Point (GCP) coordinate system and point values from a raster feature and exposes them as attributes.
Jump to Configuration
  • Extracting GCP raster properties to an attribute for use elsewhere in a workspace.
The RasterGCPExtractor receives raster features and extracts any Ground Control Points (GCPs) that exist as a raster property on the input feature. The following attributes are added to the output features:
_gcp_coordsys The GCP coordinate system.
_gcp_value
All existing GCPs, as a string.
Each GCP has five components, separated by spaces:
Column Row X-Coordinate Y-Coordinate Z-Coordinate
For example:
1442 6863 483000 5456000 0
Multiple GCPs are combined into one string, separated by semicolons:
1442 6863 483000 5456000 0;1415 1143 483000 5468000 0;4754 1120 490000 5468000 0
The GCPs are not removed from the raster properties, and so exist as both properties and attributes on the output features.
Choosing a Raster Transformer
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
Search for all results about the RasterGCPExtractor on the FME Community.
Contains information licensed under the Open Government Licence – Canada.
