RasterAspectCalculator
Calculates the aspect (direction of slope) for each cell of a raster. Aspect is measured in degrees from 0 to 360, clockwise from north.
Jump to Configuration
  • Calculating aspect on elevation rasters
The RasterAspectCalculator receives raster features, and calculates the aspect for each cell.
Aspect is calculated in degrees, from 0 to 360, clockwise from north. The calculation is done based on the values of surrounding cells (using a 3 cell x 3 cell window), and a choice of algorithms is available. Cells without data (Nodata) may be interpolated for calculation purposes. If an input band does not have a Nodata value, the output band Nodata value will be set to -1.
Aspect values are output on the same band they were calculated from, and the band is converted to Real64.
This transformer supports raster band selection. The RasterSelector can be used to modify this selection.
Choosing a Raster Transformer
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
Search for all results about the RasterAspectCalculator on the FME Community.
