RasterBandPropertyExtractor
Extracts the band and palette properties of a raster feature and adds them to a list attribute.
Jump to Configuration
  • Extracting band and palette information from raster features
The RasterBandPropertyExtractor receives raster features, and extracts any existing band and palette properties. The results are added to a new list attribute (because a raster may have multiple bands), and output with the original feature.
The transformer has no parameters.
Property attributes include:
_band{}.band_name
_band{}.band_interpretation
_band{}.band_bit_depth
_band{}.band_interleaving
_band{}.band_num_tile_rows
_band{}.band_num_tile_columns
_band{}.band_Nodata
_band{}.band_num_palettes
_band{}.palette{}.palette_name
_band{}.palette{}.palette_key_interpretation
_band{}.palette{}.palette_value_interpretation
_band{}.palette{}.palette_bit_depth
Wherever "{}" appears, there will be one instance of the attribute for each band or palette. The first will appear with {0}, the second with {1}, and so on.
If a raster band has no palettes, _band{}.band_num_palettes will be zero (0), and no further palette attributes will be added.
Choosing a Raster Transformer
Note: Feature order may change in relation to other output ports. Feature order per port is maintained.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases RasterBandPropertiesExtractor
History
Search for all results about the RasterBandPropertyExtractor on the FME Community.
