PointCloudOnRasterComponentSetter
- Applying color to a point cloud
The PointCloudOnRasterComponentSetter receives two sets of input features, PointCloud and Raster, which must be in the same coordinate system and units.
For each point in the point cloud, component values are set by extracting raster band values from the same location in the underlying raster. These values are interpolated if necessary, and a variety of interpolation methods is available. The extracted values are added to the point’s components as specified - either color (color_red, color_green, color_blue) or a Custom set of components, in which you may select any standard point cloud component to receive raster cell values (including color).
Point cloud features are output with new component values set, and rasters are discarded.
This transformer accepts multiple input point clouds and rasters. One point cloud is output for each input point cloud.
If multiple rasters are used, the component value will be taken from the first raster encountered that can provide one, and so the order of input for rasters can affect the results. If a point does not overlap a raster, the next raster will be tried, and so on until a value is obtained.
Rasters must have the same number of selected bands as there are components selected. For color, three bands are required - red, green and blue. A RasterSelector transformer may be used to meet these conditions - for example, an RGBA raster (color with an additional alpha band) would need to have only its first three bands (RGB) selected to be successfully used with the Components to Set - Color option.
This transformer supports raster band selection. The RasterSelector can be used to modify this selection.
In this example, we will apply color to a LiDAR point cloud using an orthoimage. As seen here in the FME Data Inspector, the point cloud partially overlaps the underlying orthoimage - the point cloud coverage ends at the shoreline. This view shows an overhead (2D) view of both datasets, the point cloud overlaid on the raster.
Note that the point cloud has a number of standard components, but that does not include color.
Both input features are routed into a PointCloudOnRasterComponentSetter - the point cloud (from LAS format) to the PointCloud input port, and the orthoimage (from MrSID format) to the Raster input port.
In the parameters dialog, we select the Components to Set as Color. Other parameters are left with their default settings.
The output point cloud now has color values in the color_red, color_green, and color_blue components.
- The PointCloudOnRasterComponentSetter may be useful to transfer data values when handling non-point cloud data types as point clouds for processing efficiency.
Point cloud features to overlay on the Raster input. Both Raster and PointCloud input should be in the same coordinate system.
Raster(s) from which values will be extracted. Both Raster and PointCloud input should be in the same coordinate system.
Point cloud features with updated component values.
INVALID_FEATURE_COMPONENTS
Group By |
If Group By attributes are selected, features with the same values in the Group By attributes are grouped together, and rasters are only used to set component values of point clouds in the same group. |
Complete Groups |
When All Features Received: This is the default behavior. Processing will only occur in this transformer once all input is present. When Group Changes (Advanced): This transformer will process input groups in order. Changes of the value of the Group By parameter on the input stream will trigger processing on the currently accumulating group. This may improve overall speed (particularly with multiple, equally-sized groups), but could cause undesired behavior if input groups are not truly ordered. ![]() There are two typical reasons for using When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations. The second possible reason is potential performance gains. Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains). Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with When All Features Received may be the equivalent and simpler approach. Note: Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order. As with many scenarios, testing different approaches in your workspace with your data is the only definitive way to identify performance gains. |
Components to Set |
Specifies which point cloud components should be set from the corresponding raster(s).
Components Table |
If Components to Set is Custom, select components to be set:
Extract Raster Nodata |
Specifies the behavior when a point lies on a raster Nodata value.
Default Values Overwrite Data |
Specifies the behavior when no value can be found for a point from any raster, but the component already existed on the input point cloud.
Interpolation Type |
Cell values are interpolated to arrive at point cloud component values. Select an interpolation method for determining values:
Dialog Options - Tables
Yes |
Dependencies | None |
Aliases | PointCloudOnRasterValueExtractor |
History |
Search for all results about the PointCloudOnRasterComponentSetter on the FME Community.
Keywords: point "point cloud" cloud PointCloud coerce LiDAR sonar expose extract extents orthophotos PointCloudOnRasterValueExtractor
