PointCloudComponentAdder
Adds new components with constant values to a point cloud.
Jump to Configuration
  • Adding standard or custom components to point cloud features to meet processing or format requirements.
The PointCloudComponentAdder receives point cloud features and adds one or more new components to them, with each new component set to a specified constant value. The components may be either standard named components that are not already in use on the feature, or user-specified components with non-standard names.
Each component definition consists of three parts - Component name, Data Type, and Value. A selection of data types is available, including various numeric types and strings. Values may be entered directly or obtained from an attribute or expression. The value will be applied as a constant value to all points in the point cloud feature.
  • The PointCloudExpressionEvaluator can also add components in a similar fashion, however, it does not support string values.
  • To update the values of components that already exist on a point cloud, use the PointCloudExpressionEvaluator.
  • To set individual point component values, including values derived from expressions using existing point component values, use the PointCloudExpressionEvaluator.
  • To convert attributes and values to components when converting other data types to point clouds, use the Attributes to Preserve as Components parameter in the PointCloudCombiner.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
Search for all results about the PointCloudComponentAdder on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
