PointCloudComponentTypeCoercer
Alters the data type of point cloud components, and converts component values if required.
Jump to Configuration
  • Changing component data type to meet processing or format requirements.
The PointCloudComponentTypeCoercer receives point cloud features, alters the data type of selected components, and then outputs the modified point cloud feature.
Options are available to control the manner in which values are converted, including methods for scaling values to fit a new data type and choices for rounding when converting from floating-point values to integers.
Components can be converted to any of these data types:
  • Real64
  • Real32
  • UInt64
  • UInt32
  • UInt16
  • UInt8
  • Int64
  • Int32
  • Int16
  • Int8
  • String
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases PointCloudColourScaler, PointCloudColorScaler
History
Search for all results about the PointCloudComponentTypeCoercer on the FME Community.
Keywords: PointCloudColorScaler
