PointCloudFilter
Separates point clouds into multiple features, based on evaluating expressions including component values, and creates a separate output port for each expression defined.
Jump to Configuration
  • Separating a point cloud into parts based on expressions using component values
  • Isolating points in a point cloud based on expressions using component values
The PointCloudFilter receives point cloud features and divides them into individual point clouds, based on the evaluation of defined expressions, including component values. Each Expression has a corresponding Output Port.
One or more expressions may be defined. Each output point cloud will contain the points that matched that expression. Points that match more than one expression will be allocated to the first expression they match, in table order.
Points that do not match any expressions may be optionally output as <Unfiltered>. Empty point clouds will not be output.
  • The PointCloudSplitter provides similar functionality. It can split point clouds with simple range expressions, automatically detecting unique values for a component or first/last return. It does not provide multiple output ports.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
Search for all results about the PointCloudFilter on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
