RasterBandNodataSetter
Sets a new Nodata value on selected bands of a raster feature.
Jump to Configuration
  • Defining a Nodata value for a raster that does not currently have one set, excluding cells with that value from display or processing.
  • Changing the Nodata value on a raster.
The RasterBandNodataSetter receives raster features, and adds or changes the Nodata property on any selected bands. If a band already has a Nodata value, cells with that value may optionally be changed to the new provided value.
Nodata represents an absence of data, and cells that have (or receive) the new Nodata value are ignored for most calculations, and are transparent when viewed in the FME Data Inspector and many other visualization tools.
All selected bands on an input raster feature will receive the same specified Nodata value.
To select specific bands, use the RasterSelector prior to the RasterBandNodataSetter.
This transformer supports raster band selection. Palettes are unaffected.
Choosing a Raster Transformer
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
Search for all results about the RasterBandNodataSetter on the FME Community.
