RasterCellValueRounder
Rounds off raster cell values.
Jump to Configuration
  • Rounding cell values to a fixed number of decimal places
  • Creating value ranges by rounding to powers of 10.
The RasterCellValueRounder receives raster features. All values on all bands are rounded according to the parameter selections.
Values may be rounded up, down, or to the nearest value, and are calculated to the specified number of decimal places. Negative decimal places may be used to round values to powers of ten - for example, -1 rounds to multiples of 10, -2 rounds to multiples of 100, and so on.
This transformer supports raster band selection. The RasterSelector can be used to modify selection.
Palettes are not supported.
  • If applying rounding to floating-point (decimal) values that are stored as real32, consider coercing the raster or band to interpretation type real64 prior to using this transformer to avoid unexpected results. The RasterInterpretationCoercer or RasterBandInterpretationCoercer may be used to do this.
    FME’s internal calculations are performed in real64, which is considerably more precise than real32. By converting to real64 prior to using the transformer, the calculation result will not be converted twice (once to real64 for calculations, then again back to less-precise real32 for output), where error may be introduced. Values will be output as real64.
Choosing a Raster Transformer
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
Search for all results about the RasterCellValueRounder on the FME Community.
