PointCloudTransformationApplier
- Forcing the application of transformations such as scale, offset, rotate, and shear to meet format or processing requirements.
- Creating point clouds compatible with processing, formats, or applications that cannot handle transformations.
The PointCloudTransformationApplier receives point cloud features and applies transformations that are already present on the point cloud, recalculating the affected component values and removing the transformation from the feature.
Scale and Offset may be stored on individual components, and are applied by selecting those components in the Apply Scale and Offset to Components list.
Other transformations, such as rotate and shear, will be handled with a Transformation Matrix, and are applied with the Apply Transformation Matrix parameter.
Applying a transformation is primarily done for compatibility with other processing and writers that cannot support the transformation natively.
For example, the LAS reader produces Int32 coordinates with a scale and offset. However, the POINTCLOUDXYZ writer cannot support component scale/offsets, so the transformation will be applied upon writing. The resulting coordinates will be Real64 with no transformation.
Note that processing and writers that cannot support transformations will apply them automatically, but this transformer can be used to manually apply the transformation if desired.
Note: This example is for demonstration purposes - if transformations need to be applied, for example, for compatibility with a particular writer format, it will generally happen automatically.
In this example, we start with an LAS point cloud.
Scale is the first transformation we will look at, and it already exists on the input point cloud feature. LAS uses integers to store the x, y, and z components, with a Scale applied to indicate floating-point values with a specified number of decimal places. Note that a Scale value of 0.01 exists for each of those components.
If we examine the component values of a single point in the point cloud, we can see how the Scale of 0.01 is interpreted to show coordinates with two decimal places.
Those values are still stored as integers, but are displayed as floating-point due to the Scale transformation.
The point cloud already has a Scale transformation, and we will add a rotation value by routing it through a Rotator.
In the parameters dialog of the Rotator, we set a Rotation Angle of 3.762 degrees.
Examining the point cloud as it exits the Rotator, note the newly added Transformation Matrix. Like the Scale transformation, this does not re-calculate the component values - it just describes how they are to be manipulated.
The point cloud is next routed into a PointCloudTransformationApplier. In the parameters dialog, two selections are made.
Apply Transformation Matrix (A) is set to Yes, and so the newly added Transformation Matrix will be applied, recalculating the x, y, and z components to reflect the rotation, and then removing the matrix.
The Apply Scale and Offset to Components list (B) includes the x, y, and z components, and so their Scale transformations will be applied, converting their component types from Int32 to Real64 floating-point components.
The result is a rotated point cloud, with floating-point x, y, and z components, and no Transformation Matrix.
Examining a single point in the point cloud, note the effect of recalculating the component values. The increased number of decimal places is a result of the rotation.
- This transformation does not create transformations - they must already be present on the point cloud. Transformations can be created with a number of other transformers, including the Affiner, 3DAffiner, Rotator, 3DRotator, Scaler, and Offsetter.
Point cloud features with Scale, Offset, and/or Transformation Matrix values attached.
Point clouds with recalculated component values and transformations removed.
Apply Transformation Matrix |
Whether to apply a transformation matrix. If Yes, the resulting point cloud will have x, y, and z components that are of type Real64, with no scale or offset, and no transformation matrix. |
Apply Scale and Offset to Components |
The list of components for which to apply the scale and/or offset. The resulting components will be Real64 with no scale or offset. |
Dialog Options - Tables
Search for all results about the PointCloudTransformationApplier on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
