PointCloudComponentKeeper
- Removing unused components
- Removing components to meet processing or format requirements
- Removing components to increase processing efficiency or optimize storage
The PointCloudComponentKeeper receives point cloud features, removes all components except those specified in the Components To Keep table, and outputs the modified point cloud.
Standard component names may be selected from drop-down menus, whereas user-specified names must be entered directly..
In this example, we have a large point cloud that has several components that we do not need. To optimize performance, we will remove the components we are not using.
Note that the original point cloud has thirteen components.
Each point in the point cloud has values for each component. The four components we wish to keep are outlined in yellow.
The point cloud is routed into a PointCloudComponentKeeper.
In the parameters dialog, all required components are added to the Components to Keep table.
The output point cloud now has only four components. Note that the removal of the intensity component has resulted in a slight difference in how the FME Data Inspector displays the point cloud color ramp.
The points no longer have unneeded components and values.
- The PointCloudComponentRemover and PointCloudComponentKeeper perform similar functions. The PointCloudComponentKeeper is more useful when removing a proportionately large number of components, whereas the PointCloudComponentRemover is more useful when removing a small number of components.
- The transformer cannot detect the names or existence of any given component on the input point cloud feature. A PointCloudPropertyExtractor may be used to check for the existence of components.
Point cloud features with components removed as specified.
Components to Keep |
The list of components to keep. Standard component names may be selected from the drop-down. User-specified component names must be entered directly. |
Dialog Options - Tables
Search for all results about the PointCloudComponentKeeper on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
