PointCloudComponentAdder
Adds new components with constant values to a point cloud.
- Adding standard or custom components to point cloud features to meet processing or format requirements.
The PointCloudComponentAdder receives point cloud features and adds one or more new components to them, with each new component set to a specified constant value. The components may be either standard named components that are not already in use on the feature, or user-specified components with non-standard names.
Each component definition consists of three parts - Component name, Data Type, and Value. A selection of data types is available, including various numeric types and strings. Values may be entered directly or obtained from an attribute or expression. The value will be applied as a constant value to all points in the point cloud feature.
In this example, we are preparing a LiDAR point cloud dataset for use in creating a Minecraft world. The source dataset has a number of standard point cloud components. To prepare for Minecraft world building, we need to separate different classification types and add some new Minecraft-specific components.
The point cloud is first routed into a PointCloudFilter, and then on to a PointCloudComponentAdder.
In the PointCloudFilter parameters dialog, we create one Expression/Output Port pair, which filters points with a classification value of 2 (meaning ground) into a single output feature, which is output via the defined Class 2 Ground output port.
The filtered feature is then sent to the PointCloudComponentAdder, where in the parameters dialog we add two new custom components - blockID and blockData. Both are set to a Data Type of UInt8 and have constant values assigned to them - 3 and 0, respectively.
The output point cloud feature, as viewed here in the FME Data Inspector, contains only points of classification type 2. Those points now have the additional blockID and blockData components and values, and are passed along for further processing.
- The PointCloudExpressionEvaluator can also add components in a similar fashion, however, it does not support string values.
- To update the values of components that already exist on a point cloud, use the PointCloudExpressionEvaluator.
- To set individual point component values, including values derived from expressions using existing point component values, use the PointCloudExpressionEvaluator.
- To convert attributes and values to components when converting other data types to point clouds, use the Attributes to Preserve as Components parameter in the PointCloudCombiner.
Point cloud features with added components and values as specified.
INVALID_FEATURE_COMPONENTS
Add one line per added component in this table, consisting of a set of Component name, Data Type, and Value. All three columns must exist for each component entry.
| Component | The name of the component to add. Names may be entered directly, or choose Select Component from the drop-down menu to access standard component names. |
| Type |
Select the desired type of the added component. Choices include:
| Value |
The value of the added component. This value will be assigned to all points. Values may be entered directly, or set from attribute values or expressions. |
Dialog Options - Tables
Search for all results about the PointCloudComponentAdder on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
