PointCloudThinner
Reduces the number of points in (thins) a point cloud by keeping points at a fixed interval, a maximum number of points, or a set quantity of first or last points. Remaining points are discarded.
- Reducing the data volume of a point cloud feature to meet processing or storage requirements.
- Creating a sample point cloud dataset for testing
The PointCloudThinner receives point cloud features and outputs them with fewer points than the original.
The points to keep are identified by a fixed interval, a maximum number of points, or by specifying a first or last number of points:
| Thinning Type | Amount | Result |
| Every Nth Point (Interval) | 5 | Every 5th point of the input cloud feature will be present in the output point cloud. |
| Every Nth Point (Maximum Number of Points) | 100 | The output cloud will have a maximum of 100 points, evenly spaced throughout the input. |
| First N Points | 100 | The first 100 points from the input will be kept. |
| Last N Points | 500 | The last 500 points from the input will be kept. |
In this example, we will reduce the number of points in a point cloud. Note that the original dataset has over 23 million points.
The point cloud feature is routed into a PointCloudThinner.
In the parameters dialog, Points to Keep is set to Every Nth point (Interval), and the Interval is set to 500.
Every 500th point has been retained, and all other points discarded. The output feature has only 46,110 points.
- For finer control over how a point cloud is reduced, consider using the PointCloudSimplifier transformer. It reduces while maintaining the overall shape of the original point cloud feature, however, may take considerably more processing time.
Point cloud features with a reduced number of points as specified.
| Points to Keep |
Select the method for identifying points to keep. Options include:
| Interval |
When Points to Keep is Every Nth Point (Interval), specify how often the points are retained. For example, an Interval of 10 will result in every tenth point of the input cloud feature being kept in the output point cloud. |
| Maximum Number of Points |
When Points to Keep is Every Nth Point (Maximum Number of Points) or First/Last N Points, specify the maximum points in the output point cloud. This value may be set explicitly or defined with an attribute value or an expression. |
Dialog Options - Tables
| Aliases | PointCloudSampler |
Search for all results about the PointCloudThinner on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
