Offsetter
Adds offsets to the feature's coordinates.
After you connect the transformer, you can enter parameter values as a number or pick the value of a feature attribute by picking Set to Attribute Value from the Parameter menu.
The feature will be shifted by the amounts specified.
Mode
The mode in which to offset feature coordinates.
Cartesian Coordinate Parameters
X Offset, Y Offset, and Z Offset
A separate offset must be set for each of the X, Y, and Z axes. If the input feature is 2D and a Z offset is specified, the feature is converted to 3D, and the Z offset is applied from a starting Z value of zero. If the input feature is a raster, only X and Y offset values will cause coordinate location shifts. The Z offset will cause the values in the cells of the raster to be offset by the specified amount for each selected band.
Polar Coordinate Parameters
Distance
The distance to offset the feature.
Polar Angle
Angle in degrees CCW from the positive X-axis.
Spherical Coordinate Parameters
Distance
Azimuth
Angle in degrees CW from the positive Y-axis.
Altitude
Angle in degrees from the XY plane. The angle between the XY plane and the positive Z-axis is 90 degrees.
Point Cloud
Component
Specifies a component to offset on point cloud features. Note that the x, y, and z components can be offset using the X Offset, Y Offset, and Z Offset parameters. This parameter is intended for non-spatial components (for example, intensity).
If the same component occurs multiple times in the table, each of the Offset values will be added to that component's value.
Offset
The offset that will be applied to the corresponding point cloud component.
This transformer works with both raster and vector
data.
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
This example shows an image offset using the x and y parameters:
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
Keywords: raster vector coordinates offset pointcloud
