You are here: Licensing > Single-Fixed Licenses > Troubleshooting Single-Fixed Licenses > FME is licensed but I am still having licensing trouble
- Are you having trouble with a specific format that you cannot see in the format list or FME cannot read or write to it? Some formats in FME require a higher level of licensing, and some formats are provided by 3rd party vendors. Also, some formats require another application to be installed. In particular, reading/writing ESRI Geodatabase requires a licensed ArcGIS installation and GeoMedia Access Warehouse writing requires a licensed GeoMedia installation. For a complete list of formats and required helper applications, see http://www.safe.com/fme/format-search/. If you would like to upgrade your FME to use a specific format, contact your account manager or sales@safe.com.
- Are you experiencing another problem? Contact the Technical Support Team. It may help to ensure that you are, in fact, running a fixed license. Please include the FMEReport.html file by running the FMETroubleshoot.bat file from the General Troubleshooting page.
