FME Transformers: 2025.2 BETA
Categories
Coordinates
Related Transformers
CoordinateSystemDescriptionConverter
CoordinateSystemRemover
CoordinateSystemSetter
LocalCoordinateSystemSetter
CoordinateSystemExtractor
Retrieves the name of the feature's assigned FME coordinate system into an attribute.
Jump to Configuration
  • Identifying the coordinate system of a feature or dataset.
The CoordinateSystemExtractor receives any type of geometry and retrieves its FME coordinate system name, adding it to the features as an attribute.
If the input feature does not have a coordinate system defined, or if its coordinate system is not present in the FME coordinate systems file , the attribute will have an empty value.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases CoordinateSystemFetcher
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the CoordinateSystemExtractor on the FME Community.
