RasterPaletteNodataSetter
Identifies the palette key that matches a raster band’s nodata value, and sets a value on it.
- Adding or altering the representation of nodata values on a palette.
The RasterPaletteNodataSetter receives raster features and sets a specified value on the palette key that matches the selected band’s nodata value. That is, if the nodata value is zero (0), it will find the palette entry with a key of zero (0) and change that entry’s value.
The raster band must have a nodata value already set, and have a palette.
RGB, RGBA, and string palettes are supported.
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
In this example, we have a raster with one band and two palettes. Palette 0 represents cell values as an RGB color, and palette 1 represents cell values as a text string. Note the following about the original raster:
- The Nodata Value on the band is zero (0)
- It has both an RGB24 palette and a string palette
- On the string palette. the key value zero (0) does not have an associated string value - it is blank.
We want to set a value on the string palette for nodata.
Cells that fall within the rectangular boundaries of the raster but do not fall within a zone have a value of 0, and are considered nodata. They are rendered transparently in the FME Data Inspector. In this particular area (Vancouver), they are generally water.
As the raster has more than one palette, two steps are required:
- Select the palette of interest.
- Set the value.
The raster is first routed into a RasterSelector transformer. In the parameters dialog, Selection Mode is set to Band and Palette List.
The Band and Palette List is 0 1, representing band 0 (the only band in this raster), palette 1 (the second palette, as numbering starts at 0).
The next step is to set the value using a RasterPaletteNodataSetter. In the parameters dialog, we enter Unzoned as the new Nodata Value.
On the output raster feature, the value of palette key zero (0) on Palette 1 is now Unzoned.
Cell values in the nodata region also reflect the new value.
- This transformer does not alter the nodata value on the band. To set the nodata value on the bands of a raster, use the RasterBandNodataSetter.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
This transformer accepts only raster features. Bands must have a nodata value set, and have one or more palettes.
Raster features with the specified value set on the palette key that matches the raster band’s nodata value.
INVALID_RASTER_NO_BANDS
| Nodata Value |
A numeric or string value specifying the nodata value to be set on the palette. Multi-part interpretations such as RGB or RGBA may be specified as a comma-separated value (for example, 10,0,255). The palette’s original nodata value is overwritten if one exists. |
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| History | |
| Categories |
Search for all results about the RasterPaletteNodataSetter on the FME Community.
