RasterPaletteInterpretationCoercer
Alters the interpretation type of raster palettes.
- Adding or removing alpha (transparency) values on color palettes
- Altering palette interpretation type to meet format or processing requirements
The RasterPaletteInterpretationCoercer receives raster features and alters the interpretation type of selected palettes, adjusting palette values if necessary.
Palettes may be converted to:
- RGB24
- RGBA32
- RGB48
- RGBA64
- GRAY8
- GRAY16
- STRING
A variety of options are available, depending on the Destination Interpretation Type, to specify how value conversions are handled when:
- Adding or dropping alpha values
- Converting colors to a different type (casting and scaling)
- Converting decimal values to integers
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
In this example, we have a raster with one RGB24 palette, and want to convert the palette to RGBA32 - adding an alpha (transparency) value to the palette. Note the following about the original raster:
- The raster has a Nodata Value of 0
- 0 is represented in the palette with the color black (0,0,0), but the FME Data Inspector is rendering those cells transparently due to the Nodata Value setting.
- The palette values have three components, representing red, green, and blue. The available range of values for each component is 0 to 255.
The raster is routed into a RasterPaletteInterpretationCoercer.
In the parameters dialog, Destination Interpretation Type is set to RGBA32.
Under Conversion Options, RGB to RGBA is now enabled. There are two options - Create opaque alpha component or Create alpha component from nodata.
If we chose Create opaque alpha component, all the palette values would receive a new alpha component value of 255, representing fully opaque. The areas that are currently transparent (due to the Nodata Value setting) would then be rendered as opaque black.
Instead, we choose Create alpha component from nodata. The palette key 0 (as identified by the Nodata Value) will receive a new alpha component value of 0 (fully transparent), and all the other palette keys will be set to 255 (fully opaque).
The output raster now has an RGBA32 palette. Note that palette key 0 has an alpha value of 0, and its color preview thumbnail is transparent. The rest of the palette keys have an alpha value of 255.
The raster band’s Nodata Value has been removed.
- The RasterInterpretationCoercer performs similar operations on the raster as a whole, such as converting RGB to RGBA.
- The RasterBandInterpretationCoercer performs similar conversions on individual bands.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
This transformer accepts only raster features. All selected bands must have at least one selected palette.
Raster features with palettes converted according to parameter selections.
INVALID_RASTER_NO_BANDS
| Destination Interpretation Type | Select the destination interpretation along with the bit depth. Different interpretations allow for different conversion options to be used. |
| RGBA to RGB |
Select the action to perform when converting an RGBA palette to an RGB palette:
| RGB to RGBA |
Select the action to perform when converting an RGB palette to an RGBA palette:
| Convert from Color to Color |
Select the action to undertake when a conversion between different color types occurs.
| Convert from Float to Integer |
Select the action to perform when converting from a floating-point value to an integer.
* Note: Cast and Bounded Cast use C-style casts.
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| History | |
| Categories |
Search for all results about the RasterPaletteInterpretationCoercer on the FME Community.
