RasterHillshader
Generates a grayscale shaded relief representation of terrain, based on elevation values.
- Visualizing terrain
- Generating hillshade texture for use as a background for other map data
The RasterHillshader receives elevation raster features and creates a shaded relief representation, derived from slope and aspect calculated on the input elevation values.
The input raster’s horizontal and vertical units are expected to be the same.
Input band(s) are converted to GRAY8, with hillshade values between 0 and 255. The position of the light source may be adjusted, and a choice of algorithms is available.
If the input band has a nodata value set, or if Interpolate Nodata is set to No, an ALPHA8 band is also generated, with a cell value of 0 (fully transparent) where the input was nodata and a value of 255 (fully opaque) where the input was data.
Interpolate Nodata means that nodata values will be replaced with actual values, calculated from the neighboring cells. When Interpolate Nodata is set to Yes, there are no nodata cells, and so no alpha band is required.
This transformer supports raster band selection. The RasterSelector can be used to modify this selection.
Z Factor, Scaling and Units
Input rasters’ horizontal (x and y) units are expected to be the same as vertical (z) units.
If this is not the case - for example, if the horizontal units are in meters with elevation (z) in feet (or any other similar unit type mismatch), you may apply a scale factor (also known as Z Factor) with the Scaler transformer prior to using a RasterHillshader.
In that example (ground units are meters, elevations are feet), the scale factor to use is 0.3048 - the number of meters in one foot.
If the ground units are decimal degrees (lat/long), the appropriate scale factor will vary greatly between the equator and the poles. In this case, consider reprojecting the input raster with a Reprojector, to an appropriate coordinate system with ground units matching the vertical (z) units.
If units are mismatched, the transformer may complete processing, but will produce incorrect or unexpected results.
In this example, we will generate a hillshade representation of a Digital Elevation Model (DEM). The source data ranges in elevation from sea level (0) to around 1500 meters, in a mountainous area.
Note that elevation is stored in Band 0, as 32-bit integer, and that it does have a Nodata Value set.
Note: This format, CDED, is in an LL83-SECONDS coordinate system - and so the lat/long horizontal (ground) units do not match the vertical (elevation) units in meters.
The DEM is routed first into a Reprojector, where it is converted to UTM83-10, an appropriate local coordinate system with ground units in meters, matching the elevation value units. Then it is routed into a RasterHillshader.
In the parameters dialog, we will keep the default settings. They include the light source’s Azimuth of 315 degrees and Altitude of 45 degrees, which are commonly used values. Interpolate Nodata is set to Yes, and the Algorithm is Horn.
The output raster has two bands. Hillshade values (0 to 255) are in the GRAY8 band. The ALPHA8 band represents the nodata values of the original elevation raster.
Note the shape of the output raster compared to the original DEM data - a result of the reprojection.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
Raster features with elevation values. For best results the horizontal (x and y) units should be the same as the vertical (z) units.
Raster features with hillshade values in GRAY8 bands. ALPHA8 bands will also be present if input raster features have a nodata value, or if Interpolate Nodata is set to No.
INVALID_RASTER_CANNOT_HILLSHADE
| Azimuth |
Azimuth angle of the light source, expressed in positive degrees from 0 to 360, measured clockwise from north. The default value, 315 (northwest), is commonly used to generate shaded maps. |
| Altitude |
Altitude angle of the light source above the horizon, expressed in positive degrees, with 0 degrees at the horizon and 90 degrees directly overhead. The default value, 45, is commonly used to generate shaded maps. |
| Interpolate Nodata |
Calculate values at raster edges and near nodata values. No: When any pixel in the 3x3 window used to calculate the hillshade value is equal to nodata, the output pixel will also be set to nodata. If the input band does not have a nodata value, the output band nodata value will be set to -1. There will be a one pixel border around the edge of the raster set to the nodata value. Yes: Values around the edge and near nodata values will be estimated by interpolating missing values. Note that holes will not be filled in - cells that are nodata in the input raster will remain nodata in the output. |
| Algorithm | The algorithm used to calculate slope and aspect. Some analyses have suggested that Horn's formula is better suited to rougher terrain, whereas Zevenbergen & Thorne's formula is better for smooth terrain. |
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| History | |
| Categories |
Search for all results about the RasterInterpretationCoercer on the FME Community.
