RasterPaletteAdder
Creates a palette from an attribute, and adds this palette to all selected bands on a raster.
- Adding palettes to rasters to meet format or processing requirements.
The RasterPaletteAdder receives raster features, and adds a palette to all selected bands.
The palette must be provided as an attribute, and the band(s) must have an interpretation type of UINT8, UINT16, or UINT32.
Palette keys will be discarded if they do not fit within the interpretation of a selected band. For example, when adding a palette to a UINT8 band, all keys greater than 255 will be dropped.
This transformer supports raster band selection. The RasterSelector can be used to modify selection.
Palettes
Palettes can be acquired and assigned to an attribute in a number of ways, including:
- Create a palette in a text file, and use an AttributeFileReader to load it and assign it to an attribute
- Create a palette in the workspace, as a string, using an AttributeCreator or AttributeManager
- Extract a palette from a different raster using a RasterPaletteExtractor
- Extract a palette from a different band on the same raster using RasterSelector and a RasterPaletteExtractor
Format of Palette Attributes
The general format of a palette attribute is as follows:
Format |
RGB Example |
String Example |
<value interpretation> [<string length>] |
RGB24 |
STRING 10 |
The first line of the palette must contain the value interpretation. Valid values for the value interpretation are:
- RGB24
- RGBA32
- RGB48
- RGBA64
- GRAY8
- GRAY16
- STRING
RGBA and RGB palette values consist of comma-delimited strings of integers between 0 and the maximum value of the data type. For example, a valid RGBA32 value would be 64,128,255,255, and a valid RGB48 value would be 16384,32768,65535.
When an interpretation of STRING is specified, the first line may optionally specify the maximum string length of the palette values. This value must be a positive integer. If no string length is explicitly specified, a default of 32 will be assumed.
STRING palette values may consist of any arbitrary text, except for the newline character.
GRAY palette values consist of a single integer between 0 and the maximum value of the data type.
All lines after the first are key-value pairs. Palette keys must be organized in ascending order, but they are not required to be contiguous - that is, not all numbers in the series must be present. All absent palette keys look up to 0 or an equivalent value, such as 0,0,0 for RGB or an empty string for string palettes.
In this example, we will add a color palette to a single-band numeric raster. The original raster has cells with values ranging from 0 to 8, with 0 being the Nodata Value. Note that the band’s interpretation type is INT8, and it has no palettes.
To add the palette, three steps are required:
- Change the band interpretation to a type compatible with palettes.
- Read the palette text file, and assign it to an attribute.
- Add the palette to the raster.
The raster is first routed into a RasterBandInterpretationCoercer. In the parameters dialog, Destination Interpretation Type is set to UInt8, which is compatible with palettes and accepts values between 0 and 255.
A palette has been prepared, using a text editor.
The next step is to read the palette file and assign it to an attribute, using an AttributeFileReader. In the parameters dialog, the Destination Attribute will store the contents of the file, and is named _file_contents.
The final step is the RasterPaletteAdder. In the parameters dialog, Palette Attribute is set to _file_contents, which will retrieve the palette from that attribute and apply it to the raster.
The output raster feature has one band, interpretation type UINT8, and the palette is attached and rendered by the FME Data Inspector.
- To generate a palette from the existing cell values in a raster, use the RasterPaletteGenerator.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
This transformer accepts only raster features. Bands to receive palettes must have an interpretation type of UINT8, UINT16, or UINT32.
Raster features with the provided palette added to all selected bands.
INVALID_RASTER_BANDS
INVALID_FEATURE_MISSING_ATTRIBUTES
INVALID_RASTER_PALETTE
| Palette Attribute | The attribute from which the palette will be read. |
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| History | |
| Categories |
Search for all results about the RasterPaletteAdder on the FME Community.
