RasterBandNameSetter
Sets the band name of selected bands on a raster, making raster contents simpler to understand compared to band numbers.
- Adding names to raster bands for processing requirements or clarity.
The RasterBandNameSetter receives raster features and applies either a single name or list of names to the currently selected band or bands.
To select specific bands, use the RasterSelector prior to the RasterBandNameSetter.
Lists of names must be provided as an FME list attribute.
This transformer supports raster band selection. Palettes are unaffected.
Using a List Attribute for List of Names
When the input type is a list (Input Type = List of Names), a list attribute that contains band names must be specified.
The values in the list will be applied to the selected bands, in the order they were selected. The list must contain at least as many elements as there are selected bands. List values are used sequentially.
List Examples
Given an input raster feature with three bands and no band names, this table shows the expected output for different combinations of selected bands against the same list attribute of band names.
List Attribute* |
Selected Bands* |
Resulting Band Names |
_bandnames{0} = 'OneDog' _bandnames{1} = 'TwoCats' _bandnames{2} = 'ThreeFish' |
0 1 2
Band 0: OneDog Band 1: TwoCats Band 2: ThreeFish |
0 1 2 |
Band 0: OneDog Band 1: Band 2: |
0 1 2 |
Band 0: OneDog Band 1: Band 2: TwoCats |
0 1 2 |
Band 0: Band 1: OneDog Band 2: TwoCats |
*Band numbers start at zero (0), as do list elements. The band name list attribute may have any name.
In this example, we will add a band name to a DEM raster. Note that the original raster feature has a single band, with no band name.
The raster is routed into a RasterBandNameSetter. The default state of the raster is “all bands selected,” so this raster’s single band is currently selected and will be acted on by the transformer.
In the parameters dialog, Input Type is set to Single Name, and the Band Name specified is ELEVATION.
The output raster feature now has a band name, ELEVATION.
- To create a list of names, an AttributeSplitter can be used to convert a delimited string into a list attribute.
- Existing band names may be extracted into a list attribute with the RasterBandPropertyExtractor.
Choosing a Raster Transformer
FME has an extensive selection of transformers for working with raster data. They can be generally categorized as working with whole rasters, bands, cells or palettes, and those designed for workflow control or combing raster with vector data.
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
Raster features with band names added as specified.
| Input Type |
Single Name: Set the band name of all selected bands to a specified single band name. List of Names: Set the band names of the selected bands to the names provided in a list attribute. |
| Band Name | If Input Type is Single Name, enter a band name. |
| List Attribute | If Input Type is List of Names, select a list attribute to be used. |
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| History | |
| Categories |
Search for all results about the RasterBandNameSetter on the FME Community.
