- Esri Geodatabase Reader/Writer
- Quick Facts
- Geometry Support
- Overview
- Reader Workbench Parameters
- Writer Workbench Parameters
- Feature Types
- Table Representation
- Improving the Speed of Translations Using the Geodatabase Writer
- Tips for Using the Geodatabase Writer
- Technical Reference: Mapping File Directives
- Reader Mapping File Directives
- Reader Directives - All Geodatabase Types
- Reader Directives: Geodatabase Feature Classes
- Reader Directives: Raster Dataset
- Reader Directives - Enterprise Geodatabase
- Reader Directives - Enterprise Geodatabase Feature Classes
- Reader Directives - Personal Geodatabase
- Improving the Speed of Translations Using the Geodatabase Reader
- Simple Reader Example
- Writer Mapping File Directives
- Writer Directives - Feature Classes for all Geodatabase Types
- Writer Directives - All Geodatabase Types
- Writer Directives - Enterprise Geodatabase
- Writer Directives - Enterprise Geodatabase Feature Classes
- Writer Directives - Personal and File Geodatabase
- Writer Directives - Geodatabase Raster Datasets
- Writing Subtypes and Domains
You are here: Popular Formats > Esri Geodatabase Reader/Writer > Mapping File Directives > Reader Mapping File Directives > Simple Reader Example
The example below configures a Geodatabase reader to extract features from the dataset testdset located on server tuvok. Only features located on the layer named roads that fall within the specified envelope are read from the Geodatabase.
GEODATABASE_SDE_DATASET testdset
GEODATABASE_SDE_Server tuvok
GEODATABASE_SDE_USERID joe
GEODATABASE_SDE_PASSWORD bounce
GEODATABASE_SDE_INSTANCE esri_sde8
GEODATABASE_SDE_VERSION sde.DEFAULT
GEODATABASE_SDE_HISTORICAL_VERSION_NAME New Marker
GEODATABASE_SDE_HISTORICAL_VERSION_TIMESTAMP "1/1/2006 12:00:01 AM"
GEODATABASE_SDE_SEARCH_ENVELOPE 601190 543783 611110 5447549
GEODATABASE_SDE_SEARCH_METHOD GEODB_CONTAINS
GEODATABASE_SDE_IDs roads
