Geodatabase Quick Facts
Format Type Identifier |
Reader/Writer |
Both |
Licensing Level |
Dependencies |
The bit version (32-bit or 64-bit) must be the same for FME and ArcGIS. |
Dataset Type |
Feature Type |
Feature Class name |
Typical File Extensions |
for Personal Geodatabase: .mdb , .accdb |
Automated Translation Support |
Yes |
User-Defined Attributes |
Yes |
Coordinate System Support |
Yes |
Generic Color Support |
| Appearance Support (Surfaces Only) | Yes |
Spatial Index |
Always |
Schema Required |
Yes |
Transaction Support |
Yes |
Geometry Type |
geodb_type |
Encoding Support |
Yes |
Geodatabase Geometry Support
| Geometry | Supported? |
aggregate |
yes |
circles |
yes |
circular arc |
yes |
donut polygon |
yes |
elliptical arc |
yes |
ellipses |
yes |
line |
yes |
none |
yes |
point |
yes |
polygon |
yes |
raster |
yes |
solid |
yes |
surface |
yes |
text |
yes |
z values |
yes |
Geodatabase Raster-Specific Quick Facts
| Band Interpretations | Red8, Red16, Green8, Green16, Blue8, Blue16, Gray8, Gray16, Int8, UInt8, Int16, UInt16, Int32, UInt32, Real32, Real64 |
| Palette Key Interpretations | UInt8, UInt16 |
| Palette Value Interpretations | RGB24 |
| Nodata Value | Yes |
| Cell Origin (x, y) | 0.5, 0.5 |
| Rotation Support | No |
| GCP Support | No |
| World File Support | No |
| TAB File Support | No |
Note: Esri Geodatabases can store rasters as raster datasets, raster catalogs, and raster mosaics. FME supports reading raster datasets and raster catalogs. In addition, FME supports reading mosaic datasets either as a single mosaicked raster through a raster dataset reader, or as multiple-source rasters through a raster catalog reader. Writing is supported for raster datasets but not for raster catalogs or mosaic datasets. Finally, raster support is limited to File Geodatabases and Enterprise Geodatabases.
