- Esri Geodatabase Reader/Writer
- Geodatabase Quick Facts
- Overview
- Reader Workbench Parameters
- Esri Geodatabase (ArcSDE Geodb) Reader Parameters
- Esri Geodatabase (ArcSDE Geodb Raster Catalog) Reader Parameters
- Esri Geodatabase (ArcSDE Geodb Raster Dataset) Reader Parameters
- Esri Geodatabase (File Geodb) Reader Parameters
- Esri Geodatabase (File Geodb Raster Catalog) Reader Parameters
- Esri Geodatabase (File Geodb Raster Dataset) Reader Parameters
- Esri Geodatabase (Personal Geodb) Reader Parameters
- Writer Workbench Parameters
- Feature Types
- Table Representation
- Improving the Speed of Translations Using the Geodatabase Writer
- Tips for Using the Geodatabase Writer
- Technical Reference: Mapping File Directives
- Reader Mapping File Directives
- Reader Directives - All Geodatabase Types
- Reader Directives: Geodatabase Feature Classes
- Reader Directives: Raster Dataset
- Reader Directives - Enterprise Geodatabase
- Reader Directives - Enterprise Geodatabase Feature Classes
- Reader Directives - Personal Geodatabase
- Improving the Speed of Translations Using the Geodatabase Reader
- Simple Reader Example
- Writer Mapping File Directives
- Writer Directives - Feature Classes for all Geodatabase Types
- Writer Directives - All Geodatabase Types
- Writer Directives - Enterprise Geodatabase
- Writer Directives - Enterprise Geodatabase Feature Classes
- Writer Directives - Personal and File Geodatabase
- Writer Directives - Geodatabase Raster Datasets
- Writing Subtypes and Domains
<tableName>
This specifies the name of the Geodatabase table being defined by the <WriterKeyword>_DEF statement. The name must conform to the conventions and restrictions of the underlying RDBMS database. For example, the name cannot have a hyphen (-) in it. Table name case is always preserved.
The following example shows the first portion of the definition for a table named roads.
GEODATABASE_SDE_DEF roads . . .
