- Esri Geodatabase Reader/Writer
- Geodatabase Quick Facts
- Overview
- Reader Workbench Parameters
- Esri Geodatabase (ArcSDE Geodb) Reader Parameters
- Esri Geodatabase (ArcSDE Geodb Raster Catalog) Reader Parameters
- Esri Geodatabase (ArcSDE Geodb Raster Dataset) Reader Parameters
- Esri Geodatabase (File Geodb) Reader Parameters
- Esri Geodatabase (File Geodb Raster Catalog) Reader Parameters
- Esri Geodatabase (File Geodb Raster Dataset) Reader Parameters
- Esri Geodatabase (Personal Geodb) Reader Parameters
- Writer Workbench Parameters
- Feature Types
- Table Representation
- Improving the Speed of Translations Using the Geodatabase Writer
- Tips for Using the Geodatabase Writer
- Technical Reference: Mapping File Directives
- Reader Mapping File Directives
- Reader Directives - All Geodatabase Types
- Reader Directives: Geodatabase Feature Classes
- Reader Directives: Raster Dataset
- Reader Directives - Enterprise Geodatabase
- Reader Directives - Enterprise Geodatabase Feature Classes
- Reader Directives - Personal Geodatabase
- Improving the Speed of Translations Using the Geodatabase Reader
- Simple Reader Example
- Writer Mapping File Directives
- Writer Directives - Feature Classes for all Geodatabase Types
- Writer Directives - All Geodatabase Types
- Writer Directives - Enterprise Geodatabase
- Writer Directives - Enterprise Geodatabase Feature Classes
- Writer Directives - Personal and File Geodatabase
- Writer Directives - Geodatabase Raster Datasets
- Writing Subtypes and Domains
You are here: Popular Formats > Esri Geodatabase Reader/Writer > Table Representation > Creating Geometric Networks
Currently, FME cannot be used to create geometric networks, or the feature classes participating in them. These should be created before the translation using ArcCatalog. FME can then be used to either populate these existing feature classes with point and line data, or alternately to create simple point and line feature classes, with the geometric network created as a post-processing step.
