Writer Directives – Geodatabase Raster
This section describes the directives the Geodatabase writer module recognizes when writing raster datasets.
COMPRESSION_TYPE
Required/Optional
Required
Values
LZW | JPEG | JPEG2000 | NONE
Default Value
NONE
Mapping File Syntax
GEODATABASE_FILE_RASTER_DATASET_COMPRESSION_TYPE JPEG2000
Workbench Parameter
Compression Type
COMPRESSION_QUALITY
Required/Optional
Required
Mapping File Syntax
GEODATABASE_FILE_RASTER_DATASET_COMPRESSION_QUALITY 95
Values
Positive integer (default value is 0)
Workbench Parameter
Compression Quality
PYRAMID_RESAMPLE_TYPE
Required/Optional
Required
Mapping File Syntax
GEODATABASE_FILE_RASTER_DATASET_PYRAMID_RESAMPLE_TYPE BILINEAR
Values
NEAREST (default) | BILINEAR | CUBIC
Workbench Parameter
Pyramid Resampling Method
PYRAMID_LEVEL
Required/Optional
Required
Values
positive integer
Default Value: 0
Mapping File Syntax
GEODATABASE_FILE_RASTER_DATASET_PYRAMID_LEVEL 10
Workbench Parameter
Pyramid Level
