Reader Directives – Enterprise Geodatabase
These directives are used when connecting to an Enterprise Geodatabase.
CONNECTION_FILE
Required/Optional: Optional
This statement identifies the pathname of a connection file to be used to connect to an Enterprise Geodatabase. A connection file provides the necessary information to connect to the SDE server, such as the server name or the username. The connection file must be a *.sde file and have the proper format for a connection file as defined by Esri. If you specify a connection file, you do not need to specify the directives SERVER, INSTANCE, USER, PASSWORD, VERSION, HISTORICAL_VERSION_NAME and HISTORICAL_VERSION_TIMESTAMP. (If, however, a password was not specified in the connection file, you will be prompted for a password.)
The pathname of the connection file to be used to connect to an Enterprise Geodatabase.
Parameter: <connection_file>
Workbench Parameter: Connection File
Example:
GEODATABASE_SDE_CONNECTION_FILE C:\GeoDB\connect.sde
DATASET
Required/Optional: Required
For Enterprise Geodatabases, this is the name of the dataset from which features are retrieved. In an Enterprise Geodatabase, this dataset is referred to as the DATABASE. Some RDBMS’s, such as Oracle, do not require a value, whereas others, such SQLServer, do. For databases that do not require the value, the value not_used is specified by convention.
Workbench Parameter: Source Esri Geodatabase (ArcSDE) Dataset
Example:
GEODATABASE_SDE_DATASET testdset
SERVER
The name of the Geodatabase server used to read data from the dataset.
Parameter: <server>
Workbench Parameter: Server
Example:
GEODATABASE_SDE_SERVER dax
INSTANCE
The Enterprise Geodatabase instance to which FME connects. The usual value for systems with a single ArcSDE instance is esri_sde8.
Parameter: <instance>
Workbench Parameter: Instance Name
Example:
GEODATABASE_SDE_INSTANCE esri_sde8
USERID
Required/Optional: Optional if connecting in OSA mode
User ID of the Enterprise Geodatabase user.
If the userid and password are missing or not set, then the reader will try and connect with AUTHENTICATION_MODE set to OSA (Operating System Authentication).
Parameter: <userid>
Workbench Parameter: User ID
Example:
GEODATABASE_SDE_USERID jacob
PASSWORD
Password for the user account.
Parameter: <password>
Workbench Parameter: Password
Example:
GEODATABASE_SDE_Password jacobpassword
REMOVE_TABLE_QUALIFIER
Specifies whether to keep or remove the table name prefix. For instance, the table name might appear in the form <owner_name>.<table_name>.
Setting this directive to YES indicates that the reader should return the table name without the owner_name prefix. This is useful when:
- creating a workspace that will be passed on to another organization using the same table names,
- performing a translation to another database format but with a different user name, and
- writing to a file-based format but not wanting the prefix in the name of the feature type.
When this directive is set to YES during the generation of a mapping file or workspace, the source feature types will be the table names without any prefix; otherwise, they will contain the owner name as a prefix. It is recommended that this directive not be changed in value after generating the mapping file/workspace as it is possible for no features to be successfully passed onto the writer (since the writer is expecting feature types with different names).
Notes
- Even when
REMOVE_TABLE_QUALIFIERis set toYES, if the table is owned by a user other than the current user, the<owner_name>prefix will not be dropped so that the reader will find the correct table. - When the underlying database is SQL or DB2, the schema qualifier (
<owner_name>) is always dropped, regardless of this setting.
Required/Optional
Optional
Values
YES | NO (default)
Mapping File Syntax
REMOVE_TABLE_QUALIFIER YES
Workbench Parameter
Remove Table Qualifier
SEARCH_ENVELOPE
Using the minimum and maximum x and y parameters, define a bounding box that will be used to filter the input features. Only features that interact with the bounding box are returned.
If all four coordinates of the search envelope are specified as 0, the search envelope will be disabled.
Mapping File Syntax
<ReaderKeyword>_SEARCH_ENVELOPE <minX> <minY> <maxX> <maxY>
Note: If all four coordinates of the search envelope are specified as zero, the search envelope will be disabled.
Required/Optional
Optional
Workbench Parameter
Minimum X, Minimum Y, Maximum X, Maximum Y
SEARCH_ENVELOPE_COORDINATE_SYSTEM
This directive specifies the coordinate system of the search envelope if it is different than the coordinate system of the data.
The COORDINATE_SYSTEM directive, which specifies the coordinate system associated with the data to be read, must always be set if the SEARCH_ENVELOPE_COORDINATE_SYSTEM directive is set.
If this directive is set, the minimum and maximum points of the search envelope are reprojected from the SEARCH_ENVELOPE_COORDINATE_SYSTEM to the reader COORDINATE_SYSTEM prior to applying the envelope.
Required/Optional
Optional
Mapping File Syntax
<ReaderKeyword>_SEARCH_ENVELOPE_COORDINATE_SYSTEM <coordinate system>
Workbench Parameter
Search Envelope Coordinate System
CLIP_TO_ENVELOPE
This directive specifies whether or not FME should clip features to the envelope specified in the SEARCH_ENVELOPE directive.
Values
YES | NO (default)
Mapping File Syntax
<ReaderKeyword>_CLIP_TO_ENVELOPE [yes | no]
Workbench Parameter
Clip To Envelope
