FME Transformers: 2026.2
ProjectWiseWSGConnector
Connects to Bentley ProjectWise to manage files and folders.
- Managing datasets on ProjectWise by uploading, downloading, and deleting documents and projects
- Transferring file contents into or out of an attribute in FME
- Retrieving document and project names, paths, IDs and other information from ProjectWise to use elsewhere in a workspace
The ProjectWiseWSGConnector uses your ProjectWise account credentials to perform various management tasks:
Action |
Task |
Delete |
Delete files and folders. |
Download |
Download a file or folder to an attribute, file, or folder. |
List |
List the item details for the contents of a folder. |
Upload |
Upload a file, folder, or the contents of an attribute. |
Once valid account credentials have been provided, you may browse to available content for the selected Action.
Optional Input Port
This transformer has two modes, depending on whether a connector is attached to the Input port or not:
- Input-driven: When input features are connected, the transformer runs once for each feature it receives in the Input port.
- Run Once: When no input features are connected, the transformer runs one time and outputs as many new features as the Action returns.
- This transformer cannot move or copy files between different locations. Consider using multiple connectors for these tasks, by downloading files/folders and re-uploading them to a new location.
- The FeatureReader can access ProjectWise directly but does not download a local copy of the dataset.
Features with added attributes, as specified in parameters and according to Action:
Action |
Output - Input-Driven |
Output - Run Once |
Delete |
Input feature unchanged. |
One new feature. |
Download |
One new feature. |
List |
Multiple features, one for each item in the specified location, with details about the items. |
Multiple new features, one for each item in the specified location, with details about the items. |
Upload |
Input feature with details about the uploaded item. |
New feature with details about the uploaded item. |
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute describing the category of the error will be added, along with a more descriptive fme_rejection_message which contains more specific details as to the reason for the failure.
If an Input feature already has a value for fme_rejection_code, this value will be removed.
ProjectWise Action |
Select an operation to perform. Choices include:
ProjectWise Account |
Select or create a Web Connection, connecting to the Bentley ProjectWise Web Service. The connection parameters are:
The minimum supported versions for the are Bentley Web Services Gateway 2.00 with Server Version 2.00. |
ProjectWise Path
Object |
Specify the Object Identifier of the document or project on ProjectWise to delete. Flat set objects are not supported for delete. |
Output Attributes
No attributes are added for this Action.
ProjectWise Source
Object |
Specify the Object Identifier of the document or project to download. Flat set objects will not be downloaded. |
Destination
Download as |
Select a destination type for downloaded items:
Download to Folder |
When Download as is File or Folder, specify the path to the folder that will store the downloaded item. |
Include Subfolders |
When Download as is Folder, select a method for handling subfolders:
Download to Attribute |
When Download as is Attribute, specify the attribute to contain the contents of the downloaded item. EncodingFME will attempt to convert the attribute's contents to a UTF-8 string. If this fails, the attribute's contents will be created as raw binary. To ensure that the original bytes are always preserved and never converted to UTF-8, use Download as >File instead. |
Output Attributes
ProjectWise Path
Project |
Specify the Object Identifier of the project to list the contents of. |
Output Attributes
Attributes to Add |
Select any available attributes to be included on the output features:
Source
Upload |
Select the source type:
Note that when working with large objects, File is generally the better choice as the data will be read from disk and not need to be held in memory. ProjectWise will overwrite documents of the same name. For logical set items, the target document will be overwritten and reference document relationships will be retained. Flat set objects cannot be overwritten. |
File to Upload |
When Upload is File, specify the file to be uploaded. |
Folder to Upload |
When Upload is Folder, specify the folder to be uploaded. |
When Upload is Folder, select a method for handling subfolders:
Attribute to Upload as File |
When Upload is Attribute, specify the attribute containing the content for upload. |
ProjectWise Destination
Project |
Specify the Object Identifier of the project to upload the data to. |
Upload with File Name |
When Upload is Attribute, specify the filename, including extension, to contain the uploaded content. |
Output Attributes
Attributes to Add |
Feature Output |
Select an output mode regarding the creation of Bulk Mode features:
Bulk Mode may improve performance when processing many features. Note that the transformer becomes Feature Holding, where output features can be held indefinitely when workspaces do not have a natural end, such as having a streaming transformer upstream. Individual Mode prevents these cases. |
When Feature Output is Bulk Mode. |
| Dependencies | Bentley ProjectWise CONNECT Edition, Bentley Web Services Gateway, Bentley WSG ProjectWise Plugin |
| Aliases | ProjectWiseConnector |
| History | Released FME 2018.0 |
Search for all results about the ProjectWiseWSGConnector on the FME Community.
