FME Transformers: 2026.2
OneDriveConnector
Connects to Microsoft OneDrive to manage files and folders.
- Managing datasets on Microsoft OneDrive by uploading, downloading, and deleting files and folders
- Transferring file contents into or out of an attribute in FME
- Retrieving file and folder names, paths, links and other information from Microsoft OneDrive to use elsewhere in a workspace
The OneDriveConnector uses your Microsoft OneDrive account credentials to perform various management tasks:
Action |
Task |
Delete |
Delete files and folders. |
Download |
Download a file or folder to an attribute, file, or folder. |
List |
List the item details for the contents of a folder. |
Upload |
Upload a file, folder, or the contents of an attribute. |
Once valid account credentials have been provided, you may browse to available content for the selected Action.
This connector is compatible with OneDrive personal and OneDrive for Business accounts.
Optional Input Port
This transformer has two modes, depending on whether a connector is attached to the Input port or not:
- Input-driven: When input features are connected, the transformer runs once for each feature it receives in the Input port.
- Run Once: When no input features are connected, the transformer runs one time and outputs as many new features as the Action returns.
- This transformer cannot move or copy files between different locations. Consider using multiple connectors for these tasks, by downloading files/folders and re-uploading them to a new location.
- The FeatureReader can access Microsoft OneDrive directly but does not download a local copy of the dataset.
Features with added attributes, as specified in parameters and according to Action:
Action |
Output - Input-Driven |
Output - Run Once |
Delete |
Input feature unchanged. |
One new feature. |
Download |
One new feature. |
List |
Multiple features, one for each item in the specified location, with details about the items. |
Multiple new features, one for each item in the specified location, with details about the items. |
Upload |
Input feature with details about the uploaded item. |
New feature with details about the uploaded item. |
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute describing the category of the error will be added, along with a more descriptive fme_rejection_message which contains more specific details as to the reason for the failure.
If an Input feature already has a value for fme_rejection_code, this value will be removed.
Microsoft OneDrive Action |
Select an operation to perform. Choices include:
Microsoft OneDrive Account |
Select or create a Web Connection, connecting to the Microsoft OneDrive (Graph) Web Service. |
Microsoft OneDrive Path
Object |
Specify the file or folder on Microsoft OneDrive to delete. |
Output Attributes
No attributes are added for this Action.
Microsoft OneDrive Source
Object |
Specify the file or folder to download. |
Destination
Download as |
Select a destination type for downloaded items:
Download to Folder |
When Download as is File or Folder, specify the path to the folder that will store the downloaded item. |
Include Subfolders |
When Download as is Folder, select a method for handling subfolders:
Download to Attribute |
When Download as is Attribute, specify the attribute to contain the contents of the downloaded item. EncodingFME will attempt to convert the attribute's contents to a UTF-8 string. If this fails, the attribute's contents will be created as raw binary. To ensure that the original bytes are always preserved and never converted to UTF-8, use Download as >File instead. |
Output Attributes
Folder |
Specify the folder to list the contents of. |
Output Attributes
Attributes to Add |
Select any available attributes to be included on the output features:
Source
Upload |
Select the source type:
Note that when working with large objects, File is generally the better choice as the data will be read from disk and not need to be held in memory. Microsoft OneDrive treats file uploads of the same name, in a specific folder, as overwrites, so if you upload files that already exist in that folder, they will be overwritten by the upload. |
File to Upload |
When Upload is File, specify the file to be uploaded. |
Folder to Upload |
When Upload is Folder, specify the folder to be uploaded. |
When Upload is Folder, select a method for handling subfolders:
Attribute to Upload as File |
When Upload is Attribute, specify the attribute containing the content for upload. |
Microsoft OneDrive Destination
Folder |
Specify the path on Microsoft OneDrive to upload to. To upload to the root directory, enter /. |
Upload with File Name |
When Upload is Attribute, specify the filename, including extension, to contain the uploaded content. |
Output Attributes
Attributes to Add |
Feature Output |
Select an output mode regarding the creation of Bulk Mode features:
Bulk Mode may improve performance when processing many features. Note that the transformer becomes Feature Holding, where output features can be held indefinitely when workspaces do not have a natural end, such as having a streaming transformer upstream. Individual Mode prevents these cases. |
When Feature Output is Bulk Mode. |
| Dependencies | Microsoft OneDrive account |
| History | Released FME 2017.0 |
Search for all results about the OneDriveConnector on the FME Community.
