FME Transformers: 2025.2
BoxConnector
Connects to the Box file storage service to manage files and folders.
- Managing datasets on Box by uploading, downloading, and deleting files and folders
- Transferring file contents into or out of an attribute in FME
- Retrieving file and folder names, paths, links and other information from Box to use elsewhere in a workspace
The BoxConnector uses your Box account credentials to perform various management tasks on Box:
Action |
Task |
Delete |
Delete files and folders. |
Download |
Download a file or folder to an attribute, file, or folder. |
List |
List the item details for the contents of a folder. |
Upload |
Upload a file, folder, or the contents of an attribute. |
Once valid account credentials have been provided, you may browse to available content for the selected Action.
Optional Input Port
This transformer has two modes, depending on whether a connector is attached to the Input port or not:
- Input-driven: When input features are connected, the transformer runs once for each feature it receives in the Input port.
- Run Once: When no input features are connected, the transformer runs one time and outputs as many new features as the Action returns.
- This transformer cannot move or copy files between different locations. Consider using multiple connectors for these tasks, by downloading files/folders and re-uploading them to a new location.
- The FeatureReader can access Box directly but does not download a local copy of the dataset.
Features with added attributes, as specified in parameters and according to Action:
Action |
Output - Input-Driven |
Output - Run Once |
Delete |
Input feature unchanged. |
One new feature. |
Download |
Input feature with details about the downloaded item. |
New feature with details about the downloaded item. |
List |
Multiple features, one for each item in the specified location, with details about the items. |
Multiple new features, one for each item in the specified location, with details about the items. |
Upload |
Input feature with details about the uploaded item. |
New feature with details about the uploaded item. |
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute describing the category of the error will be added, along with a more descriptive fme_rejection_message which contains more specific details as to the reason for the failure.
If an Input feature already has a value for fme_rejection_code, this value will be removed.
Box Action |
Select an operation to perform. Choices include:
Box Account |
Select or create a Web Connection, connecting to the Box Web Service. |
Box Path
Object |
Specify the file or folder to delete. |
Output Attributes
No attributes are added for this Action.
Box Source
Object |
Specify the file or folder to download. |
Destination
Download as |
Select a destination type for downloaded items:
Download to Folder |
When Download as is File or Folder, specify the path to the folder that will store the downloaded item. |
Include Subfolders |
When Download as is Folder, select a method for handling subfolders:
Download to Attribute |
When Download as is Attribute, specify the attribute to contain the contents of the downloaded item. EncodingFME will attempt to convert the attribute's contents to a UTF-8 string. If this fails, the attribute's contents will be created as raw binary. To ensure that the original bytes are always preserved and never converted to UTF-8, use Download as >File instead. |
Output Attributes
Attributes to Add |
Select any available attributes to be included on the output features:
Box Path
Generate Sharable Link |
Select an option for retrieving a link to the file or folder that may be shared:
Note that content will be viewable and downloadable by anyone with access to these links. |
Folder |
Specify the folder on Box to list the contents of. |
Output Attributes
Attributes to Add |
Source
Upload |
Select the source type:
Note that when working with large objects, File is generally the better choice as the data will be read from disk and not need to be held in memory. Box treats file uploads of the same name, in a specific folder, as duplicates, but does not allow multiple instances in a specific folder. You must upload the file to a different folder than the existing one. |
Generate Sharable Links |
Select an option for retrieving links to the file or folder that may be shared:
Both the _direct_download_link and _sharable_link will be set. Note that content will be viewable and downloadable by anyone with access to the _sharable_link. |
File to Upload |
When Upload is File, specify the file to be uploaded. |
Folder to Upload |
When Upload is Folder, specify the folder to be uploaded. |
When Upload is Folder, select a method for handling subfolders:
Attribute to Upload as File |
When Upload is Attribute, specify the attribute containing the content for upload. |
Box Destination
Folder |
Specify the path on Box to upload to. To upload to the root directory, enter /. |
Upload with File Name |
When Upload is Attribute, specify the filename, including extension, to contain the uploaded content. |
Output Attributes
Attributes to Add |
| Dependencies | Box account |
| History | Released FME 2017.0 |
Search for all results about the BoxConnector on the FME Community.
