FME Transformers: 2025.1 BETA
Categories
Database
Filters and Joins
Related Transformers
DatabaseJoiner
FeatureJoiner
InlineQuerier
ListBasedFeatureMerger
Matcher
SQLCreator
SQLExecutor
FeatureMerger
Merges the attributes and/or geometry of one set of features onto another set of features, based on matching key attribute values and expressions.
Jump to Configuration
  • Combining attributes and/or geometry from two different streams of features, based on a common key attribute value or expression.
The FeatureMerger receives two streams of features via its input ports.
Requestor: Requestors are the features that will receive new attributes and/or geometry.
Supplier: Suppliers provide attributes and/or geometry to be merged onto the Requestors.
Matches between Requestor and Supplier are identified according to the Join On configuration in the parameters dialog. The Join conditions can be simple or complex, using attribute values, constants, functions, or a combination of any of these in expression form. Multiple join conditions can be defined (features must meet all conditions to match).
When a Requestor finds a matching Supplier, the attributes and/or geometry from the Supplier are merged onto the Requestor.
  • If the Requestor already has an attribute that the Supplier also has, the Requestor's original value for that attribute can be preserved or overridden.
  • A single Supplier may be used by many Requestors.
  • Many Suppliers can be merged onto a single Requestor.
  • When attribute names conflict, you can choose whether Requestor or Supplier attribute values are maintained by using the Conflict Resolution parameter, and whether null values follow the same behavior by using the Ignore Nulls parameter.
Requestor features match Supplier features when every pair of keys (which support expressions) specified in the Join On table has the same value for both the Requestor and Supplier features.
  • For simple joins, the FeatureJoiner may provide better performance than the FeatureMerger. However, the FeatureJoiner only accepts attribute values as keys and not constructed expressions, and does not support list attributes. Additionally, the FeatureMerger is able to (optionally) restrict output to one feature in the case of multiple matching Suppliers, whereas the FeatureJoiner will create multiple features for all matches.
  • For complex joins using SQL syntax, or more than two input feature streams, consider using the InlineQuerier.
  • Where multiple FeatureMergers are required, consider using the InlineQuerier instead.
  • If all the data to be queried already exists in a SQL-capable data source, it will be more efficient to use the SQLCreator or SQLExecutor, which allows the queries and filtering of the data to be executed directly by the database before it enters the FME environment.
  • To perform a join between features already in the workspace and data residing in an external database, consider the DatabaseJoiner.
  • To perform a join where the Requestor key is a list attribute, consider using the ListBasedFeatureMerger.
  • To join features on matching geometry, consider the Matcher. The FeatureMerger does not accept geometry as a key.
  • To join all Suppliers to all Requestors when there is no common join value, setting Join On > Requestor and Join On > Supplier to the same constant value (for example, 1 and 1) will merge all to all. Enable Generate List to store multiple matches per feature.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases ReferenceResolver
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the FeatureMerger on the FME Community.
