FME Transformers: 2025.1 BETA
Categories
Database
Filters and Joins
Related Transformers
DatabaseDeleter
DatabaseJoiner
DatabaseUpdater
FeatureMerger
InlineQuerier
ListBasedFeatureMerger
Matcher
SQLCreator
SQLExecutor
FeatureJoiner
Joins features by combining the attributes and/or geometry of features based on common key attribute values. Performs Left, Inner, and Full joins.
Jump to Configuration
  • Performing simple joins between features, using attribute value(s) as keys
The FeatureJoiner performs simple join operations, much like a SQL join, without requiring knowledge of SQL query construction.
It has two input ports - Left and Right - where two streams of features to be joined are routed into the transformer. One or more attributes are selected to join on.
A Left feature matches a Right feature when every pair of keys specified in the Join On table has the same value. When a match occurs, attributes/geometry from the Left and Right feature are combined, and the combined feature is output to the Joined port.
Note that all input features must have the same coordinate system, both Left and Right.
Join Mode
The Join Mode parameter defines the type of join to be performed, determining which features will be output via the Joined output port.
Join Mode
Joined Output
Inner
  • Only features that have matching Left and Right pairs.
Left
  • Features that have matching Left and Right pairs, AND
  • All other unmatched Left features.
Full
  • All unmatched Left and Right features.
Join Behavior
A Joined feature is produced each time a Left feature is matched to a Right feature through its keys. The number of output features produced will depend on whether or not multiple Left and Right features match.
The type of join is determined by the nature of the data used (it is not a parameter). Any of these types of joins may be produced by any of the Join Modes (Inner, Left, or Full).
Cardinality
Description
Output (assuming 1 key value)
1:1
One to One: If each Left feature has a single match among the Right features (for example a single point feature is mapped to an address table via a unique address ID key), this is a 1:1 match and produces a single Joined feature.
1 Left matches 1 Right:
1 Joined Feature output
1:M
One to Many: If each Left feature has multiple matches among the Right features (for example a single address record is mapped to a list of planning applications for that address), this is a 1:M (one-to-many) match and produces a Joined feature for every match that occurs.
1 Left matches 10 Right:
10 Joined Features output
M:1
Many to One: If multiple Left features match a single Right feature record (for example a number of addresses match to the same census data via a postal code field) this is a M:1 (many-to-one) match and produces a Joined feature for every match that occurs
10 Left match 1 Right:
M:N
Many to Many: If multiple Left features match multiple Right features (for example a number of addresses match to a number of records for electrical power outages) this is a M:N (many-to-many) match and produces a Joined feature for every match that occurs.
10 Left match 10 Right:
100 Joined Features output*
*When all features have identical key values - all Left match all Right.
Unmatched Features
Features (both Left and Right) that do not find a match are handled according to the Join Mode (Inner, Left, or Full). Both the Left and Full modes will result in some or all unmatched features being output via the Joined port, depending on Join Mode:
Join Mode
Unmatched Left features output
Unmatched Right features output
Inner UnjoinedLeft UnjoinedRight
Left Joined UnjoinedRight
Full Joined Joined
  • FeatureJoiner versus FeatureMerger:
    • If the join requirements are simple, FeatureJoiner should give better performance.
    • If join requirements are more complex, such as constructing keys, using expressions, naming conflict resolution, consider using the FeatureMerger.
    • If you wish to get only one joined feature, regardless of the number of joins (1:M join produces 1 feature with a list of joins, rather than 1 feature for each join as the FeatureJoiner does), use the FeatureMerger.
    • The FeatureJoiner does not perform some of the advanced list building or geometry handling operations that the FeatureMerger does, but these may be possible by using the FeatureJoiner plus other transformers.
    • The FeatureMerger may be able to join features with different coordinate systems.
  • For complex joins using SQL syntax, or more than two input feature streams, consider using the InlineQuerier.
  • If input features are not all in the same coordinate system, the CoordinateSystemSetter, Reprojector, and related transformers may be useful.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the FeatureJoiner on the FME Community.
