FME Transformers: 2025.1 BETA
DatabaseQuerier
Executes queries against a database, either once per translation or once for each initiating feature that enters the transformer. Schema, the initiating features, and the results of the query may be output.
- Extract database records as FME features according to a SQL or Cypher statement
- Execute a database join
- Perform database table operations (create, drop, modify, truncate)
- Create or drop indexes or constraints before or after data loading
The DatabaseQuerier operates in either Input-Driven or Run Once mode.
In Input-Driven mode, the DatabaseQuerier receives features via the Initiator port, and for every feature it receives, it executes a query against an external database. The query results, as well as the initiating features, are output.
In Run Once mode, the DatabaseQuerier executes its query just once against an external database and outputs the query results.
Query statements are constructed within the transformer, using the appropriate syntax for the database in use. Spatial queries are supported if the database supports spatial predicates.
Schemas may also be produced if supported by the database. In Input-Driven mode, one schema feature will be output for every initiator feature.
In this example, we have a dataset of fire halls, which includes point geometry and some attributes. They have a street address, but not a complete postal address.
We will use a DatabaseQuerier to join a database table (using the ADDRESS field as a key), and retrieve the complete postal address.
Additionally, we will perform a second join from database table to database table, and retrieve the Civic Number for each hall.
The fire_halls dataset is connected to the Initiator port on a DatabaseQuerier. Each fire_halls feature will cause the query to be executed, for that feature.
The first step is to connect to the external database. Select the Format, in this case, PostGIS. Then configure (or select, if pre-saved) the database Connection.
Next we create a query to join both tables. Note:
- @value(ADDRESS) is providing a value from the Initiator feature - the address for a specific feature, which restricts the results to only matching records for that feature. Since the query is run every time a feature passes through, this repeats for every fire_halls feature.
- The PostalAddress table is being joined to the feature using PostalAddress field.
- The AddressPoints table (which contains the CivicNo attribute) is joined to the PostalAddress table (not the Initiator feature), using a different key - AddressId.
As the attributes will be hidden by default, we choose a set of attributes to expose on our output features.
The features with query results are output via the Result port, and have new attributes added by the query.
- If the database supports spatial predicates, spatial queries may be used.
- The SchemaScanner may also be useful as an alternative for producing schemas.
- For simple joins of one database table to features, the DatabaseJoiner may be more efficient (if the key field(s) are indexed). The DatabaseJoiner does not require knowledge of SQL.
- If all the data to be queried already exists in a SQL-capable or Cypher-capable data source, it is generally most efficient to use the DatabaseQuerier, SQLCreator or SQLExecutor, as the queries and filtering of the data is executed directly by the database before it enters the FME environment.
- Features that enter this transformer are not output until the query completes. This behavior ensures that additional DatabaseQuerier transformers, if present, do not execute their queries until the previous query completes.
Transformer |
Match By |
Uses SQL Statements |
Can Create List |
Input Type |
Notable |
Description |
FeatureJoiner | Attributes | No | No | Features |
Joins features by combining the attributes and/or geometry of features based on common key attribute values. Performs Left, Inner, and Full joins. |
FeatureMerger | Attributes | No | Yes | Features |
Merges the attributes and/or geometry of one set of features onto another set of features, based on matching key attribute values and expressions. |
ListBasedFeatureMerger | List Attribute to Single Attribute | No | Yes | Features |
InlineQuerier | SQL query | Yes | No | Features |
Creates SQLite database tables from incoming features, executes SQL queries against them, and outputs the results as features. |
SQL or Cypher query |
Yes |
External DB |
Executes queries against a database, either once per translation or once for each initiating feature that enters the transformer. Schema, the initiating features, and the results of the query may be output. |
SQLCreator | SQL query | Yes | No | External DB |
Generates FME features and/or schemas from the results of a SQL query executed against a database. One FME feature is created for each row of the results of the SQL query. |
SQLExecutor | SQL query | Yes | No | External DB |
Executes SQL queries against a database once for each initiating feature that enters the transformer. Schema, the initiating features, and the results of the query may be output. |
DatabaseJoiner | Attributes | No | Yes | External DB and Features |
Joins attributes from an external table to features already in a workspace, based on a common key or keys. |
Matcher | Geometry and/or Attributes | No | Yes | Features |
Detects features that are matches of each other. Features are declared to match when they have matching geometry, matching attribute values, or both. A list of attributes which must differ between the features may also be specified. |
When Mode is Input-Driven, features of any type that trigger a SQL query to be executed.
If requested in parameters and supported by the database, schema features are output here.
An attribute called fme_query is added to schema features containing the associated SQL.
Features that result from the queries.
Input Initiator features with an additional attribute (_matched_records) that contains the number of features generated as the result of query initiated by that feature.
When query execution fails, the original Initiator feature is output through this port with an additional attribute called _reader_error containing the last error message.
Format |
Select a database format. |
Dataset/Connection |
According to chosen format, select a dataset or use/configure a database connection. |
Parameters |
Format-specific parameters |
Coordinate System |
The coordinate system of the database being connected to (not the Initiator), as well as the coordinate system of the Result output features. |
Mode |
Select a query mode:
Query Statement |
Specify the query using the text editor. Multiple commands can be delimited by a character specified using the keyword FME_SQL_DELIMITER, embedded at the very beginning of the statement. The single character immediately following this keyword will be used to split the query which will then be sent to the database for execution. (Note: Include a space before the character.) An individual statement may be preceded with a single hyphen, indicating that errors should be ignored. Note Some database formats support comments with /* ... */ or double hyphens (--).
The following example contains two SQL commands where errors from the first command will be ignored: FME_SQL_DELIMITER ; -SELECT * FROM TABLEA; SELECT * FROM TABLEB; This applies to other query languages as well. The following example contains two Cypher commands where errors from the first command are ignored: FME_SQL_DELIMITER ; -MATCH (n) FROM GRAPHA RETURN n; MATCH (n) FROM GRAPHB RETURN n; |
Attributes to Expose |
Specify the names of attributes to include on the features created by the query. The attributes will be output in the same sequence as specified in the list. Note By default, the attributes of the resulting features are hidden. Specify which attributes to expose by entering the attribute names. Click the browse button next to the Attributes to Expose parameter. You can also use a SQL statement to populate the list by pressing “Populate from SQL Query…” and entering a SQL query. The columns from the first matching feature will be used to populate the attributes list.
Combine Attributes |
When Mode is Input-Driven:
Ignore Nulls |
When Combine Attributes is Keep Initiator Attributes if Conflict or Keep Result Attributes if Conflict:
Combine Geometry |
Features to Read |
Select the type of features to read and output:
Not applicable |
Not applicable |
Dependencies | Format-dependent - may require third-party drivers for some formats |
Aliases | |
History |
Search for all results about the DatabaseQuerier on the FME Community.
