FME Transformers: 2025.1 BETA
Categories
Web
Web
Related Transformers
AzureBlobStorageConnector
AzureFileStorageConnector
AzureQueueStorageConnector
AzureTextAnalyticsConnector
ComprehendConnector
GoogleLanguageConnector
GoogleVisionConnector
RekognitionConnector
AzureComputerVisionConnector
Connects to the Azure Computer Vision Service to detect objects in images.
Jump to Configuration
Submitting text to the Azure Computer Vision service to
  • detect individual objects
  • describe the general contents
The AzureComputerVisionConnector uses your Azure Cognitive Services account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the service.
It will submit images to the service, and return features with attributes that describe the contents of the image. Services supported are object detection, text detection, and face detection.
  • For object detection, if the service is able to identify the exact location of an object in the image, a bounding box geometry will also be returned.
  • Text detection will always return bounding boxes around the detected text.
  • For face detection, if the service is able to identify the exact location of a face in the image, a bounding box geometry will also be returned. There is also the option to detect and locate facial landmarks.
  • For better performance, requests to the Computer Vision service are made in parallel, and are returned as soon as they complete. Consequently, detection results will not be returned in the same order as their associated requests.
  • While powerful, the use of AI has important legal and ethical implications. Consult your local AI legislation and ethical guidelines before applying the AzureComputerVisionConnector in a production environment. For information about privacy and compliance with respect to Azure Cognitive Services, please see https://azure.microsoft.com/en-ca/support/legal/cognitive-services-compliance-and-privacy.
The remaining parameters available depend on the value of the Request > Detection Type parameter. Parameters for each Detection Type are detailed below.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Azure Cognitive Services Account
Aliases
History Released FME 2019.2
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the AzureComputerVisionConnector on the FME Community.
