FME Transformers: 2025.1
Categories
Integrations
Web
Web
Workflows
Related Transformers
ArcGISAttachmentConnector
ArcGISBranchVersionManager
AzureBlobStorageConnector
GoogleCloudStorageConnector
S3Connector
ArcGISOnlineConnector
Connects to Esri ArcGIS Online or Portal for ArcGIS to manage ArcGIS items.
Jump to Configuration
  • Managing datasets and supplementary files on ArcGIS Online or Portal for ArcGIS by uploading, downloading, publishing, sharing, and deleting files and folders
  • Transferring file contents into or out of an attribute in FME
  • Retrieving file and folder names, paths, links and other information from ArcGIS Online or Portal for ArcGIS for use elsewhere in a workspace
  • Retrieving or updating metadata
The ArcGISOnlineConnector uses either your ArcGIS Online or Portal for ArcGIS account credentials to perform various management tasks on Esri ArcGIS Online or Portal for ArcGIS:
Action Task
Delete
Delete an item from a user’s own ArcGIS Online content.
Download
Download a file or folder to an attribute, file, or folder from a user’s ArcGIS content or group they have access to.
Get Details
Get details for an item, including its metadata.xml file.
List
List the item details for the contents of a group, a user’s folder, a user’s root folder, or all of a user’s content.
Publish
Publish an existing ArcGIS item as a feature service. See Publishing below.
Set Details
Update the details for an item or overwrite its metadata.xml file.
Share
Change the sharing level of a user’s ArcGIS Online content item or share it to additional groups.
Update
Update the contents of an existing ArcGIS item and optionally specify a new title or tags.
Upload
Upload a file or attribute to a location in a user’s ArcGIS Content.
Once valid account credentials have been provided, you may browse to available content for the selected Action.
Publishing
The following ArcGIS item types are supported for publishing with this transformer:
  • Shapefile
  • CSV
  • Microsoft Excel
  • Feature Collection
  • GeoJSON
  • File Geodatabase
  • Scene Package
  • SQLite Geodatabase
  • Image Collection
  • Service Definition
  • Tile Package
  • Compact Tile Package
  • Vector Tile Package
CSV and Excel files will be analyzed and have some publishing parameters auto-generated for them, which are logged at the info level.
For CSV files, ArcGIS will attempt to classify the file as containing either coordinate data, address data, lookup data, or no location data.
If a CSV file is classified as having location data but ArcGIS cannot determine which fields contain this data, the ArcGISOnlineConnector will log a warning and publish the CSV file as though it does not contain any location data. The resulting feature service will be a table.
  • This transformer cannot move or copy files between different locations. Consider using multiple connectors for these tasks, by downloading files/folders and re-uploading them to a new location.
  • Uploading data to ArcGIS is performed via synchronous multipart upload. Each file chunk is 20MB. The connector will upload these chunks consecutively. If a chunk upload fails, the connector will retry each upload up to five times.
  • Early termination of translations during Publish, Update, or Upload actions may result in malformed ArcGIS item entries. When publishing, a feature service may be created but any title or tags specified for it may not be honored. When updating or uploading, it is possible for the metadata to be uploaded before the file content has been uploaded.
  • The FeatureReader can access online ArcGIS content directly but does not download a local copy of the dataset.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Esri Access
Aliases AGOLConnector ArcGISPortalConnector
History Released FME 2020.1
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the ArcGISOnlineConnector on the FME Community.
