FME Transformers: 2025.1
ArcGISAttachmentConnector
Connects to an ArcGIS Feature Service to manage attachments.
- Attaching images, PDFs, or other files to ArcGIS Feature Service features
- Updating or deleting existing attachments
- Listing attachment metadata for validation or logging
- Downloading attachments for local storage or further processing
The ArcGISAttachmentConnector connects to an ArcGIS Feature Service to perform various tasks:
| Action | Task |
Add |
Upload a new attachment. |
Delete |
Delete a feature’s attachments. |
Download |
Download an attachment. |
List |
List attachment details. |
Update |
Replace an attachment. |
Feature URLs
Feature URLs follow this form:
https://<feature_service_url>/<layer_id>/<object_id_of_feature>
They may be obtained with an Esri ArcGIS Feature Service reader (also available in the FeatureReader transformer) and are stored in the arcgisfeatureservice_feature_url format attribute. These may be used to provide values for the Feature URL parameter.
Note that the object ID (not the global ID) is required.
- When accessing branch-versioned feature services, the ArcGISAttachmentConnector will only download or modify attachments on the default branch of the feature service. See ArcGISBranchVersionManager.
Features with added attributes, as specified in parameters and according to Action:
| Action | Output |
Add |
Input feature with details about the new item. |
Delete |
Input feature with details about deleted attachments. |
Download |
Input feature with details about the downloaded attachment. |
List |
Multiple features, one for each attachment on the specified feature, with details about the attachments. |
Update |
Input feature with details about the updated attachment. |
Input features are output here unmodified, in addition to any other output locations (Output or <Rejected>).
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute describing the category of the error will be added, along with a more descriptive fme_rejection_message which contains more specific details as to the reason for the failure.
If an Input feature already has a value for fme_rejection_code, this value will be removed.
Connection |
Select or create a Web Connection, connecting to the appropriate Web Service:
Action |
The type of operation to perform. Choices include:
Feature
Feature URL |
Specify the URL of the feature where attachment operations will be performed. |
Data Source
Upload |
Select the source type:
Note that when working with large objects, File is generally the better choice as the data will be read from disk and not need to be held in memory. |
File to Add |
When Upload is File, specify the file to be uploaded. |
Attribute to Add as File |
When Upload is Attribute, specify the attribute containing the content for upload. |
Metadata
Add with Filename |
When Upload is Attribute, specify the filename, including extension, to contain the uploaded content. |
Keywords |
(Optional) Specify any keywords for the attachment (if enabled in the feature service settings). |
Added Attributes
Output features will receive these attributes:
_attachment_id |
The object ID of the newly added attachment. |
_global_id |
The global ID of the newly added attachment. |
Request
Delete All Feature Attachments |
Select an option for attachment deletion:
Feature
Feature URL |
Specify the URL of the feature where attachments will be deleted. |
Attachment ID |
When Delete All Feature Attachments is No, specify the ID of the attachment to delete. |
Added Attributes
_attachment_id |
The object ID of the deleted attachment, when Delete All Feature Attachments is No. |
_total_attachments |
Total number of attachments on the feature, when Delete All Feature Attachments is Yes. |
_attachments_deleted |
Total number of attachments deleted, when Delete All Feature Attachments is Yes. |
_attachment_ids |
List of deleted attachments, when Delete All Feature Attachments is Yes. |
_deletion_errors |
List of attachments that were not deleted successfully with their respective errors, when Delete All Feature Attachments is Yes. |
Feature
Feature URL |
Specify the URL of the feature from which attachments will be downloaded. |
Attachment ID |
Specify the ID of the attachment to download. |
Destination
Download as |
Select a destination type for downloaded items:
Download to Folder |
When Download as is File, specify the path to the folder that will store the downloaded item. |
If File Exists |
When Download as is File, select a method for handling existing files:
Download to Attribute |
When Download as is Attribute, specify the attribute to contain the contents of the downloaded item. |
Added Attributes
These attributes will be added to the output features:
_downloaded_path |
The local path where the downloaded attachment is saved, when Download as is File . |
_filename |
The filename of the downloaded file. |
_file_size |
The size of the downloaded file in bytes. |
_content_type |
The MIME type of the downloaded file. |
Feature
Feature URL |
Specify the URL of the feature to list the attachments of. |
Output Attributes
Attributes to Add |
Select any available attributes to be included on the output features:
Feature
Feature URL |
Specify the URL of the feature where attachments will be updated. |
Attachment ID |
Specify the ID of the attachment to update. |
Data Source
Upload |
File to Add |
Metadata
Keywords |
Add with Filename |
When Upload is Attribute, specify the filename, including extension, to contain the updated content. |
Added Attributes
Output features will receive this attribute:
_attachment_id |
The object ID of the updated attachment. |
| Dependencies | Esri Access |
Search for all results about the ArcGISAttachmentConnector on the FME Community.
