FME Transformers: 2025.0
PointCloudExtractor
Serializes the geometry of a point cloud feature into a Blob attribute, encoding the contents according to a choice of common binary point cloud formats.
- Storing point clouds in databases that do not support specific point cloud types but do support Blobs
Storage of point cloud geometry, as a temporary backup within a workspace
The PointCloudExtractor receives point cloud features and puts a copy of the point cloud geometry into an attribute, as a Blob - a Binary Large OBject.
The Blob content may be encoded as a variety of common point cloud formats. The name of the chosen format will also be recorded in an attribute for reference when decoding.
There are no parameters in the transformer to control how the point cloud is formatted, and encoding is done based on default settings for the chosen format. If necessary, format-specific settings may be overwritten by setting format attributes on the point cloud feature, prior to using the PointCloudExtractor. Consult the appropriate format’s Writer documentation for a complete list of available attributes and format limitations.
As the point cloud exits the transformer, it has two copies of its geometry - its original geometry and a copy as a Blob in an attribute.
In this example, we will prepare and write a point cloud to a PostgreSQL database, which does not support geometry as an attribute type.
The point cloud feature is routed into a PointCloudExtractor, and then on to a PostgreSQL Writer.
In the parameters dialog, Format is set to LAZ, and the Format Name and Blob attributes are left with the default names applied.
Examining the output from the PointCloudExtractor in the FME Data Inspector, note that the feature has two added attributes - _pointCloudBlob, containing the encoded point cloud, and _pointCloudFormatName, containing the name (LAZ) of the chosen encoding.
In the writer parameters, User Attributes, the Type of _pointCloudBlob is adjusted to bytea, which stores binary strings. (Note that the appropriate data type may vary between database formats.)
- When writing the point cloud Blob Attribute to a database, you may need to adjust the database User Attribute type to an unbounded data type to avoid truncation of the data. Choose an appropriate attribute type depending on the destination format.
- The PointCloudReplacer may be used to perform the reverse operation and convert the encoded blob back to the original point cloud geometry.
- To carry out a similar operation on vector data, use the GeometryExtractor transformer. For raster data, use the RasterExtractor.
- To remove the original geometry after using a PointCloudExtractor (leaving only the Blob attribute version), use a GeometryRemover.
- The AttributeFileWriter transformer can be used to write the point cloud Blob Attribute directly to a file.
Point cloud features with both their original geometry and a copy of their geometry encoded as an attribute as specified.
INVALID_FEATURE_CANNOT_WRITE
Format |
The point cloud format used to encode the blob. Choices include:
Format Name |
Name the attribute to contain the selected Format name. |
Blob |
Name the attribute to contain the encoded Blob. |
Search for all results about the PointCloudExtractor on the FME Community.
