FME Transformers: 2025.0
PointCloudCreator
Creates a point cloud of specified size and density, with default component values.
- Testing a workspace
- Creating point cloud placeholders
The PointCloudCreator creates a single point cloud feature, based on specified size, location, spacing, rotation, and components. Size may be defined either by an origin with X and Y Length (in ground units), or by extents (lower left and upper right coordinates).
Patterns may be created for z values and/or any other component.
Z Values
Z values may be applied in a selection of patterns:
Flat |
The Z Minimum value is applied to all points, producing a flat point cloud. |
Sloped |
Z values are scaled between the Z Minimum and Z Maximum, producing an elevation gradient. |
Trigonometric |
Z values are assigned in a trigonometric pattern, producing waves that range between the Z Minimum and Z Maximum values. The Z Component Type must be floating-point - either Real32 or Real64. |
Oblique view:
None |
The point cloud will not have a z component - only x and y components. |
Components
Other components may also be created and patterned. Standard component names may be selected from the drop-down, and user-defined names can be entered directly. The component Data Type, Min Value, and Max Value are specified.
All component values are applied in the same selected Value Pattern, shown here as an intensity component on a sloped point cloud:
Value Pattern |
Value Pattern on a Sloped Point Cloud |
Single Value |
One component value is applied to all points. Note the color gradient represents the underlying z value of the Sloped point cloud - not the Single Value component value. |
Checkered Pattern |
A checkerboard pattern is applied, where one set of blocks is set to Component Values > Min Value. The alternating blocks are filled with a gradient of component values, scaled between Min Value and Max Value. |
Checkerboard |
A checkerboard pattern is applied, where one set of blocks is set to Component Values > Min Value, and the alternating blocks are set to Max Value. |
In this example, we will create a point cloud for testing purposes, enabling us to run and test a workspace before the actual data is available. A PointCloudCreator is added to the workspace.
In the parameters dialog, we define the size of the point cloud by choosing Size Specification > Origin and Size.
Both the X and Y Component Types are Int32 (32-bit integers), and the X Length and Y Length are set to 1000, with Average Spacing (for points) along both axes as 1. The origin is 0,0 as defined by the X and Y Lower Left Coordinates.
Z values will be created in a Trigonometric pattern, and so the Z Component Type must be floating-point. Real32 is selected. The values will range between the Z Minimum and Z Maximum values of 0 and 100.
One component is added, classification, and its values will range from 0 to 18 in a Checkered Pattern.
These Z Values and Component Values selections will provide a range of values to test against in the workspace.
A point cloud feature is output as specified, and is passed along to the next transformer and can now be used in the workspace.
Viewing the feature from an oblique angle in the FME Data Inspector, note that the individual points have z and classification values interpolated between the specified minimum and maximum values.
This transformer has no input ports.
One point cloud feature, according to the specified parameters.
X Component Type Y Component Type |
Select the data type of the x and y components. Options include integer and floating-point numeric types. If an integer data type is chosen, and the corresponding Average Spacing Along X/Y value produces coordinates that are not integers, an appropriate Scale will be calculated and applied. |
Size Specification |
Select a method for defining the point cloud size along the x and y axes:
X Lower Left Coordinate Y Lower Left Coordinate |
Specify the lower left (origin) coordinates of the point cloud. The default is 0,0. |
X Length Y Length |
When Size Specification is Origin and Size, specify the length of the point cloud along the x and y axes, in ground units. |
Average Spacing Along X Average Spacing Along Y |
Specify the distance between points in the point cloud, in ground units. |
X Upper Right Coordinate Y Upper Right Coordinate |
When Size Specification is Extents, specify the upper right coordinates. |
Rotation |
Specify a rotation angle if required. The default is 0. Rotation angle is measured in degrees counterclockwise from horizontal, and measures the rotation of the primary axis from horizontal. |
Z Pattern |
Select a method for assigning z values to individual points in the point cloud:
Z Component Type |
Select the data type of the z components. Options include integer and floating-point numeric types. |
Z Minimum Z Maximum |
Specify the minimum and maximum z values as required by the selected Z Pattern. |
Value Pattern |
Select a pattern for component values to be assigned. All components will have the same pattern.
Note If Checkered Pattern or Checkerboard are used with a string component, blocks will alternate between the two strings provided.
The Component Values table is used to specify additional components to be added to the point cloud. One complete line is required per component.
Component |
Select or enter the component name. Standard names are available from the drop-down. |
Data Type |
Select a data type for the component. Choices include string and numeric types. |
Min Value |
Specify the minimum value to be used according to the Value Pattern. |
Max Value |
Specify the maximum value to be used according to the Value Pattern. Max Value is not used when the Value Pattern is Single Value. |
Search for all results about the PointCloudCreator on the FME Community.
