FME Transformers: 2025.0
PointCloudSurfaceBuilder
Takes an input point cloud and reconstructs it into an output mesh.
Input features having point cloud geometry.
Reconstructed mesh features.
Point clouds which are unable to be reconstructed, as well as non-point cloud geometries are output via the <Rejected> port.
Construction Mode |
Specifies whether to use Simple Triangulation, Poisson, or Marching Cubes reconstruction. Simple Triangulation uses a greedy algorithm to connect points into surfaces. Poisson reconstruction creates a closed, smooth mesh. Marching Cubes uses the Hoppe signed distance function to estimate the distance of each point to a surface. |
Normal Estimation Tolerance |
The maximum number of neighbors to consider when performing normal estimation. |
Clip Output Mesh |
Specifies whether to clip the output mesh based on the distance between mesh vertices and original point cloud points. |
Clipping Distance |
The maximum allowable distance between each vertex in the output mesh and the closest point in the original point cloud. Vertices beyond this limit will be removed from the output mesh. |
Search Radius |
The maximum distance between points. Practically, this is the maximum edge length for every triangle. |
Multiplier |
The maximum acceptable distance for a point to be considered, relative to the distance of its nearest point. |
Maximum Nearest Neighbors |
The maximum number of neighbors to consider when performing surface reconstruction. |
Minimum Angle (Degrees) |
The minimum angle in each triangle. |
Maximum Angle (Degrees) |
The maximum angle in each triangle. |
Maximum Surface Angle (Degrees) |
Sets the maximum angle between point normals. Above this maximum, points will not be connected. |
Consistent Normals |
Specifies whether input normals are consistently oriented. |
Consistent Vertex Ordering |
Sets whether output triangle vertices should be ordered consistently. |
Maximum Depth |
Specifies the maximum depth of the tree that will be used for surface reconstruction. Higher values can result in more detailed output at the cost of performance. |
Minimum Depth |
Specifies the minimum depth of the tree that will be used for surface reconstruction. Higher values can result in more detailed output at the cost of performance. |
Point Weight |
Specifies the importance that interpolation of the point samples is given in the formulation of the screened Poisson equation. The results of the original (unscreened) Poisson Reconstruction can be obtained by setting this value to 0. |
Scale |
Specifies the ratio between the diameter of the cube used for reconstruction and the diameter of the samples’ bounding cube. |
Solver Divide Depth |
Sets the depth at which a block Gauss-Seidel solver is used to solve the Laplacian equation. This parameter can be used to reduce memory overhead at the cost of a small increase in reconstruction time. Solver Divide Depth must be greater than or equal to Minimum Depth. |
Isosurface Divide Depth |
Sets the depth at which a block iso-surface extractor should be used to extract the iso-surface. This parameter can be used to reduce memory overhead at the cost of a small increase in extraction time. Isosurface Divide Depth must be greater than or equal to Minimum Depth. |
Samples Per Node |
Specifies the minimum number of sample points that should fall within an octree node as the octree construction is adapted to sampling density. Larger values should be used for more noisy input data. |
Confidence |
Enabling this parameter causes normals to be used as confidence information. When disabled, normals are normalized to have unit-length before reconstruction. |
Output Polygons |
Specifies whether a polygon mesh or a triangle mesh should be output. |
Manifold |
Enabling this parameter causes the polygon barycenter to be added when triangulating polygons with more than three vertices. |
Grid X Resolution |
Sets the resolution along the x-axis of the cubic grid used for processing. Higher values will generally give more detailed results, at the cost of longer processing time. |
Grid Y Resolution |
Sets the resolution along the y-axis of the cubic grid used for processing. Higher values will generally give more detailed results, at the cost of longer processing time. |
Grid Z Resolution |
Sets the resolution along the z-axis of the cubic grid used for processing. Higher values will generally give more detailed results, at the cost of longer processing time. |
Isosurface Level |
Sets the iso level of the surface to be extracted. |
Grid Extend Percentage |
Sets the percentage of the bounding box that should be left empty between the bounding box and the grid limits. |
Search for all results about the PointCloudSurfaceBuilder on the FME Community.
