FME Transformers: 2025.0
LineBuilder
Connects sequential point and/or line features to create line or area geometry.
- Connecting points to form a line
- Connecting multiple lines into longer, continuous lines
The LineBuilder receives features with point and/or line geometry, and connects them in the order received, producing line or area geometry.
Both the order in which the features enter the transformer and the orientation of any line geometry received are honored. Gaps between line features are connected, and duplicate points may be either processed or ignored.
Z values are supported. If some input features have z values and others do not, those without are assigned a z value of zero (0). Features with matching x and y coordinates but differing z values are not considered duplicates.
If the output feature is closed (the first and last x and y coordinates are the same), an area is output whether or not the z values match.
Features may be grouped by attribute values to produce multiple outputs.
Attributes may be merged, dropped, or collected as List Attributes.
In this example, we have a set of point features captured by GPS along a route. We want to create a line from these sequential points.
The features are routed into a LineBuilder.
In the parameters dialog, the default settings are used.
A single line feature is output, connecting all of the input points in the order they were received.
- The Sorter may be useful for ordering features before using the LineBuilder.
- As the LineBuilder fills in gaps between features, it can produce unexpected results if the input features are not sorted correctly. To combine adjoining lines (without creating new geometry to connect gaps), use a LineCombiner.
- The CoordinateSwapper may be useful in specific cases.
Creating and Modifying Linear Features
These transformers work with lines in a variety of ways.
Transformer |
Use this to... |
Transformer Description |
Create one or more new features with box geometry of a specific size and position (when Geometry Object is Line). |
Create simple lines from lines and/or points. |
Connects sequential point and/or line features to create line or area geometry. |
Combine adjoining lines into longer lines or complex paths, with more advanced geometry handling options than the LineBuilder. |
Connects line features that meet at common start or end points to create longer lines or paths. |
Combine arcs and lines into longer paths. |
Connects sequential line and/or arc features to create path geometry, preserving input segments. |
Convert linear features into areas. |
Converts a linear feature to an area by connecting the end point to the start point. |
Extend linear geometry. |
Extends line, arc, or path features at both ends by a specified length. |
Chop features into smaller features, breaking them at their existing vertices. |
Chops line, arc, path, or area features into smaller features based on number of vertices or approximate length. |
Break a path into its component segments (lines and arcs). |
Splits path geometry into its component line and/or arc segments. |
Shorten linear geometry. |
Shortens linear geometry by cutting off the ends. |
Intersect lines and areas. |
Overlays lines and areas, intersecting geometry and sharing attributes. |
Intersect lines and lines. |
Overlays lines on lines, intersecting geometry, sharing attributes, and producing intersection points. |
Find where points lay on lines. |
Overlays points on lines, splitting lines and sharing attributes. |
If the resulting feature is a single point, it will be output through this port.
If the resulting feature does not begin and end at the same point, it is output through this port.
If the resulting feature forms a ring (begins and ends at the same point), it is output through this port.
Any features that are not points or lines are output through this port.
Group By |
The default behavior is to use the entire set of input features as the group. This option allows you to select attributes that define which groups to form – each set of features that have the same value for all of these attributes will be processed as an independent group. If only one point feature was received with a given value for the Group By value, it will be output as a Point. If the feature output forms a ring (begins and ends at the same point), it is output as a Polygon. Anything else is output as a Line. |
Complete Groups |
Remove Duplicate Points |
Select a method for handling consecutive vertices with identical coordinates, such as occur where the LineBuilder connects lines that meet end-to-end:
Accumulation Mode |
Specify how attributes are accumulated on combined lines:
Generate List
When enabled:
Yes |
| Aliases | PointConnector |
Search for all results about the LineBuilder on the FME Community.
