FME Transformers: 2025.0
LineExtender
Extends line, arc, or path features at both ends by a specified length.
Preparing geometry for further processing
The LineExtender receives features with line, arc, or path geometry and extends them at both ends by a specified length in ground units.
Extension angle is the same as the orientation of the line segment leading to the extension point (the first or last vertex). Arc geometry extensions are also straight lines, placed tangent to the arc.
Optionally, the angle of a number of segments back from the point of extension can be averaged. If the Segments to Average value is larger than the number of segments available on the feature, the entire feature orientation is averaged. For arc geometry, the segments are produced by default arc stroking which can produce unpredictable angles.
Two-point linear extensions are output individually as Beginning and End.
A Stretched geometry is also produced. If extended from a line segment, the start and end vertices of the input feature are moved to the end position of the extensions. If extended from an arc, the end vertices remain intact.
If the stretched geometry includes an arc or path, it is output as a path.
Output features receive the same attributes as the input feature.
Z coordinates are supported.
Segments to Average |
Input |
Beginning and End |
Stretched |
| Default (1) |
2 |
Default (1) |
18 |
This transformer may be useful in combination with the Snapper and Intersector to perform simple data cleaning.
Creating and Modifying Linear Features
These transformers work with lines in a variety of ways.
Transformer |
Use this to... |
Transformer Description |
Create one or more new features with box geometry of a specific size and position (when Geometry Object is Line). |
Create simple lines from lines and/or points. |
Connects sequential point and/or line features to create line or area geometry. |
Combine adjoining lines into longer lines or complex paths, with more advanced geometry handling options than the LineBuilder. |
Connects line features that meet at common start or end points to create longer lines or paths. |
Combine arcs and lines into longer paths. |
Connects sequential line and/or arc features to create path geometry, preserving input segments. |
Convert linear features into areas. |
Converts a linear feature to an area by connecting the end point to the start point. |
Extend linear geometry. |
Extends line, arc, or path features at both ends by a specified length. |
Chop features into smaller features, breaking them at their existing vertices. |
Chops line, arc, path, or area features into smaller features based on number of vertices or approximate length. |
Break a path into its component segments (lines and arcs). |
Splits path geometry into its component line and/or arc segments. |
Shorten linear geometry. |
Shortens linear geometry by cutting off the ends. |
Intersect lines and areas. |
Overlays lines and areas, intersecting geometry and sharing attributes. |
Intersect lines and lines. |
Overlays lines on lines, intersecting geometry, sharing attributes, and producing intersection points. |
Find where points lay on lines. |
Overlays points on lines, splitting lines and sharing attributes. |
Features with line, arc, or path geometry to be extended.
A two-point line feature extending from the first vertex of the input feature according to parameter selections.
A two-point line feature extending from the last vertex of the input feature according to parameter selections.
Geometry composed of the input feature with start and end vertices moved to the extended positions (if extending from lines) or the input features with extensions added (if extending from arcs).
Features with geometry other than valid line, arc, or path geometry are output via this port.
INVALID_GEOMETRY_DEGENERATE
INVALID_PARAMETER
Extension Length |
Specify the length to extend the features, in ground units. |
(Optional) Specify a number of segments to be averaged when calculating the extension line orientation. If empty, one segment is used. |
| Aliases | Extender |
Search for all results about the LineExtender on the FME Community.
