FME Transformers: 2024.1
PointCloudMerger
- Transferring component values between co-located point clouds
- Performing change detection on point clouds
- Removing duplicate points from point clouds
The PointCloudMerger receives point cloud features and merges them, identifying matching individual points based on component values which may include both location (x, y, and z components) and other standard or user-defined components.
There are two input ports:
- Requestor: Point clouds that will receive merged component values, and
- Supplier: Point clouds that will provide new component values.
Requestor and Supplier points are successfully matched when the components specified in the Join On parameter all have the same value for both the Requestor and Supplier.
Multiple point clouds may be sent to either port, and they may be grouped. The same point cloud may be connected to both input ports.
There are multiple output ports, each producing an output point cloud with the following characteristics:
- Merged: Points from the Requestor that successfully found a match and received component values from a Supplier point.
Where duplicate Supplier points are found, only the first one encountered is used, therefore Requestor points are not duplicated. - Not Merged: Points from the Requestor that did not find a match in the Supplier.
For change detection purposes (where the Requestor is the original point cloud), these may have been deleted or had a component value changed. - Referenced: Points from the Supplier that were successfully matched to a Requestor point, and had their component values transferred onto that Requestor point.
- Unreferenced: Points from the Supplier that were not matched to a Requestor point.
For change detection purposes (where the Requestor is the original point cloud), these may have been added or had a component value changed. - Duplicate Supplier: Points from the Supplier that have the same Join On component values as a point that was previously Referenced.
When a Requestor finds a Supplier, the components from the Supplier are merged on to the Requestor. If the Requestor already had a component with the same name, the Conflict Resolution parameter controls which value is preferred for the merged point cloud.
In this example, we have two co-located point clouds, each with a different set of components.
The first one has a selection of standard components, but does not have classification.
The second point cloud has a classification component.
Both point clouds are routed into a PointCloudMerger. The first (A) is the Requestor, and the second (B) is the Supplier. Any components on B will be merged onto A.
In the parameters dialog, a join is defined for the x, y, and z components, matching individual points on position only.
The point cloud output from the Merged port contains all points that found a positional match, and has components from both original point clouds.
In this example, we have two point clouds - one of which is a thinned version of the other. We want to identify which points were deleted in the thinning process.
The initial point cloud (A) has 23,035,567 points.
The thinned point cloud (B) has 10,000,000 points.
Both point clouds are routed into a PointCloudMerger. The original (A) is the Requestor, and the thinned point cloud (B) is the Supplier.
In the parameters dialog, a join is defined for the x, y, and z components, matching individual points on position.
The point cloud output from the Merged port will contain the points that existed both in the original and the thinned versions.
The point cloud output from the NotMerged port contains 13,035,567 points that were in the original and did not appear in the thinned version - therefore, they were deleted.
In this example, we have an XYZ point cloud of 10,000,000 points. The file is over 600 MB, and we want to reduce the complexity of it.
Note that the coordinates are floating-point values.
We will do this in two steps:
- Round the coordinate values by converting them from floating-point to integer using a PointCloudComponentTypeCoercer.
- Identify and discard the resulting duplicates with a PointCloudMerger.
In the parameters dialog of the PointCloudComponentTypeCoercer, the x, y, and z components are converted to type Int32 (32-bit integer), and rounded.
Note that the coordinate component values are now integers.
The point cloud is now routed into the PointCloudMerger as both the Supplier and the Requestor - effectively merging it with itself.
The coordinate rounding produced a large number of duplicated point positions. In the case where a location contains multiple points with different classification values, we want to keep one of each classification.
A join is created on the x, y, and z components for position, and classification is joined as well.
When a merge is performed, each unique Supplier point (with uniqueness determined by the combination of all defined Join On component values) is used only once. The first instance is output in the Referenced point cloud, and all duplicates are output in the DuplicateSupplier point cloud.
By merging the point cloud with a copy of itself, all unique Referenced points will be output exactly once - effectively stripping duplicates from the point cloud.
Note that the Referenced point cloud has 2,696,791 points - down from the original 10,000,000.
- To concatenate or combine point clouds together (as opposed to merging component values), use the PointCloudCombiner.
- A single point cloud can be connected to both input ports, providing a way to identify and remove duplicate points.
- When merging based on x, y, and z components, the values must match exactly. A PointCloudExpressionEvaluator may be used to round the values and ensure matching.
Point clouds to be matched to and receive component values from Suppliers.
Point clouds to be matched to and provide component values to Requestors.
Requestor points that find a matching Supplier, with component values transferred from those Suppliers.
Requestor points that do not find a matching Supplier.
Supplier points that are found by at least one Requestor.
Point clouds output via this port will have an additional reference_count component added, specifying the number of times each point was referenced.
Supplier points that are not found by any Requestor.
Supplier points with the same Join On component values as an earlier Supplier point.
Group By |
If Group By attributes are selected, features with the same values in the Group By attributes are grouped together, and point clouds will only be merged with other point clouds in the same group. |
Complete Groups |
Each line in this table specifies a component join pair. Multiple pairs may be defined, including coordinates and other standard or user-defined components.
Points are only considered a match if the values for all components included in this table are equal.
Requestor |
Requestor component to be joined on. |
Supplier |
Supplier component to be joined on. |
Note that the drop-down menus for both Requestor and Supplier provide a list of standard component names. User-specified component names may be entered directly in both columns.
Conflict Resolution |
Conflicts occur when Requestors and Suppliers both have a component with the same name.
Yes |
Search for all results about the PointCloudMerger on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
