FME Transformers: 2024.1
PointCloudComponentCopier
Copies selected component values onto either a new or existing component.
- Creating copies of components and their values to meet processing requirements
- Creating backup copies of values before manipulating them
The PointCloudComponentCopier receives point cloud features, copies specified components and their values onto new or existing components, then outputs the modified point cloud feature.
The Source Component remains intact, and the Target Component will be created (if new) or have its values overwritten (if existing).
Multiple components may be copied.
In this example, we want to create backup copies of the x, y, and z component values in a point cloud before performing manipulations on them.
Note that the source point cloud has x, y, and z components.
The point cloud is routed into a PointCloudComponentCopier.
In the parameters dialog, we make three entries in the Components to Copy table - one for each of x, y, and z. New component names are assigned in the Target Component column, which will be added as new components.
The output point cloud feature has three new components, containing a copy of the original components’ values, and is passed on into the workspace for further processing.
If desired, another PointCloudComponentCopier could be used after x,y, and z are manipulated - copying from the new orig_x, orig_y, and orig_z back onto x, y, and z - to restore the original values.
- To create or update components with values more complex than simply copying, consider using the PointCloudExpressionEvaluator.
- To add a new component with a constant value, use the PointCloudComponentAdder.
- To copy values from a raster onto point cloud components, use the PointCloudOnRasterComponentSetter.
- To change the name of a component while retaining its values (elevation to z, for example), use the PointCloudComponentRenamer.
Point cloud features with components added or updated as specified in the parameters.
MISSING_FEATURE_COMPONENTS
Each line in this table specifies a component to be copied, and parameters for doing so. Multiple components may be modified.
Source Component |
The source component to copy from. |
Target Component |
The target component to copy to. If this component already exists, its values will be overwritten. |
Note that the drop-down menu for both Source and Target Component provides a list of standard component names. User-specified component names may be entered directly in both columns.
Search for all results about the PointCloudComponentCopier on the FME Community.
