FME Transformers: 2024.1
PointCloudComponentRemover
Removes specified components from a point cloud.
- Removing unused components
- Removing components to meet processing or format requirements
- Removing components to increase processing efficiency or optimize storage
The PointCloudComponentRemover receives point cloud features, removes specified components, and outputs the modified point cloud.
Standard component names may be selected from drop-down menus, whereas user-specified names must be entered directly. Multiple components may be removed.
In this example, we have a large point cloud that has several components that we do not need. To optimize performance, we will remove the components we are not using.
Note that the original point cloud has thirteen components.
Each point in the point cloud has values for each component. The components we wish to keep are outlined in yellow.
The point cloud is routed into a PointCloudComponentRemover.
In the parameters dialog, all unneeded components are added to the Components to Remove table.
The output point cloud now has only 7 components.
The points no longer have unneeded components and values.
- The PointCloudComponentRemover and PointCloudComponentKeeper perform similar functions. The PointCloudComponentKeeper is more useful when removing a proportionately large number of components, whereas the PointCloudComponentRemover is more useful when removing a small number of components.
- The transformer cannot detect the names or existence of any given component on the input point cloud feature. A PointCloudPropertyExtractor may be used to check for the existence of components.
Point cloud features with components removed as specified.
Components to Remove |
The list of components to remove. Standard component names may be selected from the drop-down. User-specified component names must be entered directly. |
Search for all results about the PointCloudComponentRemover on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
