FME Transformers: 2024.1
GtransAttributeReprojector
Reprojects coordinates stored as attributes from one coordinate system to another using the Gtrans reprojection engine from the National Land Survey of Sweden (Lantmäteriet).
- Reprojecting features when explicitly using the Gtrans library is desired
- Adding additional coordinate pairs as attributes, in alternate coordinate systems
The GtransAttributeReprojector accepts any feature. The user specifies the attributes containing X and Y Coordinates, and selects a Transformation File to reproject them from one coordinate system to another, using the Gtrans engine.
Gtrans is widely used for coordinate transformation within Sweden as it is officially recommended, translates between numerous local coordinate systems, and supports rubbersheeting transformations.
The transformation is configured by selecting a Gtrans Translation File appropriate for the Source and Destination Coordinate System.
Translation Files
A selection of Gtrans Translation Files are provided with FME.
Only reprojections defined here or with a user-provided Gtrans Translation File (see below) may be performed with this transformer.
File Type |
Description |
Location |
*.tf, *.tfi |
Translation File - a text file containing parameters defining a reprojection from one coordinate system to another.
[FME Install Directory]\Reproject\Gtrans\Sys |
*.tr1, *.tr2 |
Triangulation File - a binary file used for the interpolation of residuals.
Each *.tf/*.tfi file corresponds to a line item in the Gtrans Translation Files library accessed in the parameters dialog.
Note that when using the Filter option, FME searches the file names of the *.tf/*.tfi files - not the Source and Destination Coordinate Systems.
Geoid Files
When reprojecting between geoids, this transformer needs additional resource files.
File |
Description |
Location |
geoid.def |
Geoid Definition File - a text file containing parameters describing geoids. A default version is provided with FME. User-provided geoids may also be used - see below. |
*.grd |
Binary Grid files for specific geoids. |
Gtrans User Data
Users may provide their own transformations and definitions by placing the appropriate files as directed:
File(s) |
Description |
Location |
*.tf, *.tfi |
The Translation File should reference the correct geoid.def and any required *.bin files. User-defined translations are placed in the same location as the provided Translation Files. |
geoid.def |
Geoid Definition File - a text file containing parameters describing geoids. A default version is provided with FME. The user version of this file is placed in a different location than the default geoid.def provided with FME. |
[FME Install Directory]\Reproject\Gtrans\Arkiv |
*.bin |
In this example, we have a shapefile of point of interest (POIs) in Sweden, extracted from OpenStreetMap. Note that its Coordinate System is lat/long, WGS84.
We want to do two things - first, extract the center coordinates of each feature into attributes, and then reproject those attributes into an appropriate national coordinate system using the Gtrans engine.
The features are routed into a CenterPointExtractor, and then into a GtransAttributeReprojector.
In the parameters dialog of the CenterPointExtractor, we assign names to the new attributes which will contain the point coordinates.
As the features exit the CenterPointExtractor, they have two new attributes containing their extracted coordinates.
In the parameters dialog of the GtransAttributeReprojector, the X and Y Attributes are set to the values of the newly added coordinate attributes.
A Translation File is also selected.
The Translation File was selected from the Gtrans Translation Files gallery, via the ellipsis button. Note that the chosen Source Coordinate System is SWEREF 99 lat long, an equivalent to LL-WGS84
The output features have not been reprojected - but the coordinates stored as attributes have been.
TFFIL Lantmäteriet 2006-08-24
Överräkning mellan SYSTEM:
SWEREF 99 13 30 Ellh-> SWEREF 99 lat long ellh
FSYSTEM SWEREF 99 13 30 Ellh/
HTYP ELLIPSOID METER/
TSYSTEM SWEREF 99 lat long ellh/
LATLONG DEG/
ELLIPSOID GRS 80/
PROJ GAUSS
G 13 30 0 DEG
0
150000
1
STOP /
GEOID SWEN08_RH2000 grid
Geoidhöjdsmodell för SWEREF 99,
bilinjär interpolation i grid SWEN08_RH2000.grd, geografiska lat long
Gridstorlek: 801x376
lat-min: 54° long-min: 10°
lat-max: 70° long-max: 25°
dlat: 0°.02 dlong: 0°.04
ELLIPSOID GRS 1980
GRIDSYSTEM SWEREF 99 lat long
HSYSTEM RH 2000
GRIDFIL SWEN08_RH2000.grd
GEOID SWEN08_RH70 grid
bilinjär interpolation i grid SWEN08_RH70.grd, geografiska lat long
ELLIPSOID GRS 1980
HSYSTEM RH 70
GRIDFIL SWEN08_RH70.GRD
- This transformer does not change the feature's coordinates – it only changes the values of the selected X and Y attributes (if they contain coordinate values).
- FME has a Workspace Parameter, Reprojection Engine, that may be set to either FME (CS-Map) or Esri. This transformer will override this parameter setting.
- The AttributeReprojector provides similar functionality, and will use the default library (CS-Map or Esri) set in FME. It supports some Swedish coordinate systems, but will not use the Gtrans definitions or reprojection engine.
- To reproject coordinates stored as geometry, consider using the GtransReprojector.
Coordinate System Support
Library |
FME (default) or Esri |
Library (External Links) |
Sweden |
Sweden |
Switzerland |
Features with attributes containing coordinates to be reprojected.
Features with reprojected attributes as specified in parameters.
X Attribute |
Provide the attribute containing the X coordinate to be reprojected. |
Y Attribute |
Provide the attribute containing the Y coordinate to be reprojected. |
Translation File |
Enter the path and filename of the desired Translation File. Files may be selected from the Gtrans Translation File gallery via the ellipsis button. |
| Dependencies | Gtrans software and Translation Files, included with FME. |
Operating System Restrictions |
Win64, Win32, and Linux are supported. Not available on Mac. |
Search for all results about the GtransAttributeReprojector on the FME Community.
Example contains data © OpenStreetMap contributors.
Keywords: SWEREF99 "National Land Survey of Sweden" Sweden
