FME Transformers: 2024.1
EsriReprojector
Reprojects feature coordinates from one coordinate system to another using the Esri reprojection engine.
- Reprojecting features when explicitly using the Esri reprojection engine is desired.
The EsriReprojector receives features and reprojects their coordinates from one coordinate system to another, using Esri coordinate system definitions and the Esri reprojection engine.
It is not necessary to have Esri products installed to use it.
Both a Source and Destination Coordinate System must be specified, and any coordinate system previously set on the input features will be ignored. Coordinate systems may be selected from a list of available choices, or provided in an attribute value or user parameter. Values must be in the form ESRIWKT|<name>|<esriwkt> where <name> is the coordinate system name, and <esriwkt> is the WKT (Well-Known Text) representing the coordinate system.
If the selected pair of coordinate systems has appropriate Geographic Transformations available, they will be provided.
Both predefined and custom geographic transformations are supported.
Predefined Esri coordinate systems and geographic transformations may be found here.
Geographic transformation names are case-sensitive.
You can also enter GEOGTRAN Well Known Text that represents a geographic transformation.
Custom transformation files (*.gtf files) can be stored in a number of locations that the EsriReprojector will search for.
All platforms, including without Esri products installed:
<FME_HOME>\Reproject\EsriPEGridData\customTransformation
With Esri products installed:
On Windows systems, additional folders inside the users %appdata% folder will also be searched.
These folders are used by relevant ArcGIS products. If you create a custom transformation inside one of the supported ArcGIS products, the *.GTF file will be stored in the related folder inside %appdata%.
Supported products include ArcGIS Pro, Desktop 10.2 → 10.8.
Full list of %appdata% directories:
%appdata%\Esri\ArcGISPro\ArcToolbox\CustomTransformations
%appdata%\Esri\Desktop10.8\ArcToolbox\CustomTransformation
%appdata%\Esri\Desktop10.7\ArcToolbox\CustomTransformations
%appdata%\Esri\Desktop10.6\ArcToolbox\CustomTransformations
%appdata%\Esri\Desktop10.5\ArcToolbox\CustomTransformations
%appdata%\Esri\Desktop10.4\ArcToolbox\CustomTransformations
%appdata%\Esri\Desktop10.3\ArcToolbox\CustomTransformations
%appdata%\Esri\Desktop10.2\ArcToolbox\CustomTransformations
Rasters
Additional parameters are available for raster features, specifying how the reprojected cells are to be interpolated.
This transformer is not affected by raster band and palette selection.
Vertical and Time-Dependent Transformations
Optional parameters for handling time-based (epoch) and vertical transformations are also available.
In this example, we have a scanned topo map, georeferenced to UTM zone 10, NAD 27. We want to reproject it to NAD 83.
The raster is routed into an EsriReprojector.
In the parameters dialog, appropriate source and destination coordinate systems are selected. Note that this combination of source and destination has several possible Geographic Transformation choices. As the topo is located in Canada, we select the NTv2 Canada option.
Raster settings are left as default.
The output raster has been reprojected.
- FME also has a Workspace Parameter, Reprojection Engine, that may be set to either FME (CS-Map) or Esri. Using this transformer will override this parameter setting.
- When using Epoch, only inter-frame transformations are supported, where input and output features are the same epoch. To transform from one epoch to another, consider using the PROJReprojector.
Coordinate System Support
Library |
FME (default) or Esri |
Library (External Links) |
Sweden |
Sweden |
Switzerland |
Features reprojected as specified in parameters.
Source Coordinate System |
Select the coordinate system of the incoming features. Available Esri coordinate systems can be accessed via the ellipsis button, where coordinate systems may also be imported. The coordinate system may also be provided as Esri WKT via an attribute or user parameter. Values must be in the form ESRIWKT|<name>|<esriwkt> where <name> is the coordinate system name, and <esriwkt> is the WKT (Well-Known Text) representing the coordinate system. The coordinate system selected here will override any coordinate system already attached to the features. |
Select the coordinate system to be reprojected to. Available Esri coordinate systems can be accessed via the ellipsis button, where coordinate systems may also be imported. The coordinate system may also be provided as Esri WKT via an attribute or user parameter. Values must be in the form ESRIWKT|<name>|<esriwkt> where <name> is the coordinate system name, and <esriwkt> is the WKT (Well-Known Text) representing the coordinate system. |
Geographic Transformation |
A selection of available geographic transformations is provided once a Source and Destination Coordinate System are set. |
Epoch |
(Optional) A decimal year value representing the time dimension to be used, for time-dependent geographic transformations. The value may also be an ISO or FME formatted datetime. If the Geographic Transformation provided is time-dependent, and no Epoch is supplied, then the translation will fail. If the Geographic Transformation provided is not time-dependent, and an Epoch is supplied, then the Epoch will be ignored and the translation will continue. Note Only inter-frame transformations are available at this time - that is, both the input and output features will have the same epoch.
Vertical Handling |
Select a method for transforming height values on incoming features:
Source Vertical Coordinate System |
Select the vertical coordinate system of the incoming features. Available Esri vertical coordinate systems can be accessed via the ellipsis button, where vertical coordinate systems may also be imported. The vertical coordinate system may also be provided as Esri WKT. |
Destination Vertical Coordinate System |
Select the vertical coordinate system to be reprojected to. Available Esri vertical coordinate systems can be accessed via the ellipsis button, where vertical coordinate systems may also be imported. The vertical coordinate system may also be provided as Esri WKT. |
Vertical Transformation |
A selection of available vertical transformations is provided once a Source and Destination Vertical Coordinate System are set. The vertical transformation may also be provided as Esri WKT. |
Interpolation Type |
Select a method for interpolating reprojected cell values:
Cell Size |
Select a method for resizing cells:
Tolerance (cells) |
Sets the tolerance, in cells, for approximating reprojected cell locations. Using the default value of 0.0, every cell will be reprojected. If a value greater than 0.0 is specified, some cell locations will be approximated. The difference between an approximated cell location and the true cell location should be at most the tolerance value. For example, if a value of 0.5 is specified, each approximated cell location should be maximum one-half of a pixel away from its true location. Increasing the Tolerance value may improve performance. |
| Aliases | ESRIReprojector |
Search for all results about the EsriReprojector on the FME Community.
