FME Transformers: 2024.1
EllipsePropertySetter
Modifies or creates ellipse geometry according to new coordinate, radii, rotation, or orientation values.
Modifying ellipse or circle geometry
The EllipsePropertySetter receives features with ellipse or point geometry. Ellipses are modified if any values provided in parameters differ from the input geometry. Points are converted to ellipses if at least a New Primary Radius value is provided.
The parameters may modify or create an ellipse as a closed Arc By Center Point by the following:
Center X, Y, and Z coordinates
Primary and Secondary Radius in ground units
Rotation in degrees
Orientation
An assumed sweep of 360 degrees
Values may be entered or provided through attribute values, expressions, or user parameters.
Features without valid ellipse or point geometry will be rejected, as will points that do not have the required parameter values to create an ellipse.
For more information on ellipse geometry see Ellipse.
In this example, we have a set of ellipse features and wish to set them all to the same rotation.
The features are routed into an EllipsePropertySetter.
In the parameters dialog, a New Rotation value is provided.
The output ellipses are modified accordingly.
To create ellipses, consider using the 2DEllipseReplacer.
To extract ellipse properties to use in expressions, use an EllipsePropertyExtractor before the EllipsePropertySetter.
Creating and Modifying Arcs, Circles, and Ellipses
These transformers work with arcs in a variety of ways.
Function |
Geometry Out |
Z Coordinates |
Creates one or more new features with arc geometry (when Geometry Object is an arc type). |
Arc by center point Arc by center point with ends Arc by 3 points Arc by bulge Ellipse (Arc by center point) |
Supported |
Replaces any existing feature’s geometry with a 2D arc. |
Arc by center point |
Replaces any existing feature’s geometry with a 3D arc. |
Yes, at center point |
Replaces an existing feature’s geometry with a 2D ellipse or circle (closed arc). |
Modifies an existing arc or converts a point to an arc. |
Arc by center point Arc by center point with ends Arc by 3 points |
Supported, at center and/or ends |
Modifies an existing ellipse (closed arc) or converts a point to an ellipse. |
Supported, at center point |
Extracts the property values that describe an arc’s geometry and stores them as attributes. |
Arc by center point Arc by center point with ends Arc by 3 points Arc by bulge |
Supported |
Extracts the property values that describe an ellipse’s geometry and stores them as attributes. |
Supported |
Converts arcs and ellipses to lines or polygons by interpolating points along the arc. |
Path Line Area |
Supported |
Replaces geometry with an arc described by the first, middle, and last vertices of the input feature. |
Arc by 3 points |
Supported |
Replaces lines or polygons with an optimal combination of line and arc segments, creating smooth curving lines. |
Path Area Arc by bulge Line |
Supported |
Reduces point density on lines or polygons, fitting arcs where possible (When using Algorithm > Douglas With Arc Fitting (Generalize) ). |
Path Area Arc by 3 points Line |
Supported |
Either replaces an existing feature’s geometry with circle that contains all of its vertices or extracts the circle property values into attributes. |
Features with ellipse or point geometry.
Features with ellipse geometry modified or created as specified in parameters.
Features without valid ellipse or point geometry are output via this port, as well as points that do not have the required parameter values to create an ellipse.
Features that receive non-numeric values for any numeric parameters are output via this port.
INVALID_PARAMETER_PRIMARY_RADIUS
INVALID_PARAMETER_SECONDARY_RADIUS
INVALID_PARAMETER_ROTATION
INVALID_PARAMETER_CENTER_POINT
New Primary Radius |
Specify the new primary radius of the ellipse in ground units. Note that the primary radius need not be larger than the secondary, however, the rotation angle is always measured from the x axis to the primary axis. For a circle, set both the primary and secondary radius to the same value. |
New Secondary Radius |
Specify the new secondary radius of the ellipse in ground units. |
New Rotation |
Specify the new rotation in degrees of the primary axis from horizontal (if any). |
New Orientation |
Can change the orientation of a feature, following the right-hand rule or the left-hand rule. |
New Center X |
Specify the new X coordinate of the ellipse’s origin. |
New Center Y |
Specify the new Y coordinate of the ellipse’s origin. |
New Center Z |
Specify the new Z coordinate of the ellipse’s origin. |
Search for all results about the EllipsePropertySetter on the FME Community.
