FME Transformers: 2024.1
Creator
Creates features using the parameters supplied, and sends them into the workspace for processing.
The Creator's interface allows you to select the desired type of geometry, then enter the coordinates and/or parameters that will create the desired object.
This transformer does not have any input ports.
All created features are output through this port.
Geometry Source |
This parameter specifies how to create the geometry, using the options listed below. Your choice for this parameter determines whether other parameters are enabled or disabled.
Geometry Object |
The Geometry Creator dialog is accessed via the ellipses button. In this dialog, a Geometry Type is selected and appropriate tabs are enabled to define the object being created:
3D coordinates may be toggled on to add z coordinates to the parameters.
GeoJSON |
Creates a geometry based on the GeoJSON spec. |
Coordinate System |
This parameter allows you to set the coordinate system on the specified feature. Select a coordinate system from the pull-down list, or click the Browse button to select from the Coordinate System Gallery. If you leave this parameter blank, the coordinate system will not be set on the feature(s) created by this transformer. |
Number to Create |
This parameter specifies how many features will be created. When more than one feature is created, the attribute specified by the Creation Instance Attribute parameter will hold each feature's creation number (starting from 0). |
Create After Readers |
Create After Readers determines whether the feature is created after all reader features have been processed (Yes), or whether the feature is created immediately before the first reader feature is processed (No). Features cannot be created in the data flow before any reader reads anything, since the data flow is driven by features arriving from the reader. In rare cases, you might want the Creator to specifically operate before other features are processed. |
Creation Instance |
When more than one feature is created (see the Number to Create parameter above), this attribute will hold each feature's creation number (starting from 0). |
Search for all results about the Creator on the FME Community.
