FME Transformers: 2024.1
2DGridCreator
Creates a regular grid of points or rectangular polygons of a specified size, position, and coordinate system.
Creating reference grids
Creating clipping polygons
The 2DGridCreator creates a single grid of regularly spaced features, which may be composed of:
rectangular polygons,
points at the corners of each cell, or
points at the center of each cell.
Cell size is specified by Column Width and Row Height, in the units of the specified Coordinate System.
A Starting Corner is selected (Lower Left is the default), along with a Starting X and Y Coordinate. Grid cells are calculated and numbered from this point accordingly for a specified number of columns and rows.
This transformer does not receive input features.
In this example, we will generate a grid along lines of latitude and longitude.
A 2DGridCreator is added to a workspace.
In the parameters dialog, we specify cell size, position, grid extent, and coordinate system. Type of Grid to Create is Polygons.
A grid of rectangular polygons is produced.
Note that the cells are numbered from the selected Starting Corner (Lower Left), starting at 0,0.
If Type of Grid to Create is Points (Corners), point features are placed at all cell corners.
Points (Centers) places a single point at the center of each cell, as shown here in conjunction with the Points (Corners) grid.
Creating Boxes and Rectangles
Creating rectangular geometry is a common task. These transformers do so in a variety of ways.
Transformer |
Function |
Creates one or more new features with box geometry of a specific size and position (when Geometry Object is Box). |
Replaces an existing feature’s geometry with a box of a specific size and position. |
Creates one rectangle that encompasses all features received. |
Individually replaces the geometry of each feature with a rectangle that covers its extents. |
Individually replaces the geometry of each raster feature with a rectangle that covers its extents (with various Extents Type options). |
Extracts the coordinate values that describe an individual feature’s bounding box (or cube) and stores them as attributes. |
Creates a series of regularly-spaced rectangles that span the extent of all features received (when Type of Grid to Create is Polygons). |
Creates a series of regularly-spaced rectangles of a specific size and position (when Type of Grid to Create is Polygons). |
Tiler and RasterTiler |
Do not create actual rectangles, but chop features into a series of rectangular tiles, specified in a similar fashion to the 2DGridAccumulator. |
This transformer has no input ports.
A grid of polygon or point features as specified in parameters.
Starting Corner |
Select the starting corner for calculating the grid and numbering the columns and rows.
Starting X Coordinate |
Specify the position of the Starting Corner on the x axis. |
Starting Y Coordinate |
Specify the position of the Starting Corner on the y axis. |
Number of Columns |
Specify the number of cells to create horizontally. |
Number of Rows |
Specify the number of cells to create vertically. |
Column Width |
Specify the cell width, in ground units. |
Row Height |
Specify the cell height, in ground units. |
Type of Grid to Create |
Select the grid type:
Coordinate System |
(Optional) Set the coordinate system of the generated grid. |
Column |
Name the attribute to contain column numbers, relative to the Starting Corner. Numbering starts at 0. |
Row |
Name the attribute to contain row numbers, relative to the Starting Corner. Numbering starts at 0. |
Not applicable. |
Not applicable. |
Dependencies |
None |
Aliases |
History |
Search for all results about the 2DGridCreator on the FME Community.
